oxygen sensors
  • Sponsors(?)
Greenscobie86
132
The Island NY
I used the ones from the baqck for the front ones... No problems... The little color coded plugs on mine don't match up, but everything still works great anyways.
My verdict is: yes. they are the same.
Mstg05
103
Delaware county, pa
Switch them if you want, tell you the truth, I don't really care what you do. Call a ford dealership and ask what the part numbers are for a front o2 sensor and a rear o2 sensor. Compare the part numbers then find out for yourself if they are the same.
Thread starter Similar threads Forum Replies Date
D Oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
D **HELP NEEDED** O2 PIGTAIL WIRES 1996 - 2004 SN95 Mustang -General/Talk- 2
D O2 sensor harness 1994 - 1995 Specific Tech 0
D Oxygen sensor help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
Onesick99GT Exhaust Wideband Oxygen Sensors Help Needed SN95 4.6L Mustang Tech 8
K Help P1151 SN95 V6 Mustang Tech 1
fredfifty Exhaust Leak At O2 Bung Fox 5.0 Mustang Tech 33
A Plesae Help With Oxygen Sensor Sorting Out Fox 5.0 Mustang Tech 6
D Emissions Problem - Very High Hc Fox 5.0 Mustang Tech 35
T Please Help O2 Sensor Hookup 5.0 Swap 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
T Engine 2005 V6 Oxygen Sensor / Cel Problem 2005 - 2009 Specific Tech 0
Blown88GT For Sale 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 3
des89stang SOLD 87-93 Denso Oxygen Sensors, Nib. Other Classifieds 4
Luis911 Electrical I Had Code 92, Exchanged Oxygen Sensors, Now Code 42 (update Now Code 44 And 94) Fox 5.0 Mustang Tech 7
Blown88GT SOLD 2 Bosch Oxygen Sensors, Nib Engine and Power Adder 11
L Changing Front Oxygen Sensors SN95 4.6L Mustang Tech 5
L Oxygen Sensor Clean Up SN95 4.6L Mustang Tech 0
Luis911 Engine Useful Life Of The Oxygen Sensor Fox 5.0 Mustang Tech 6
M Removing Oxygen Sensor Questions 1994 - 1995 Specific Tech 3
J 95 3.6L V6- Oxygen Sensor SN95 V6 Mustang Tech 3
8 oxygen sensor socket SN95 4.6L Mustang Tech 5
93lxtwin Oxygen sensors Fox 5.0 Mustang Tech 9
90silverstang Running Rich,A9M ECU and Oxygen Sensor question Fox 5.0 Mustang Tech 13
arnie93lx 87-93 M/T oxygen sensor harness Engine and Power Adder 1
R WILL 2001 gt oxygen sensors work in my 96 GT SN95 4.6L Mustang Tech 1
Tripoli Upstream Oxygen Sensors - On with open loop tune? SN95 4.6L Mustang Tech 8
I upstream vs downstream oxygen sensor 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
hollywoodstang oxygen sensors and off-road H pipe 1994 - 1995 Specific Tech 16
J oxygen sensors SN95 4.6L Mustang Tech 5
M 99 cobra oxygen sensor harness SVT Tech Forum 2
Hi-Po Oxygen sensors - Code 41 Fox 5.0 Mustang Tech 2
babybudistmonk Oxygen Sensors 2.3L (N/A & Turbo) Tech 3
M oxygen sensor wiring-92 2.3L (N/A & Turbo) Tech 2
tx65coupe 1997 Cobra Oxygen Sensors SVT Tech Forum 2
C Tell Me If I'm Crazy. Oxygen Sensors SN95 4.6L Mustang Tech 17
V oxygen sensors question on a 97 4.6L V8 SOHC -which one goes where? SN95 4.6L Mustang Tech 0
V oxygen sensors on a 97 4.6L V8 SOHC -which one goes where? 1996 - 2004 SN95 Mustang -General/Talk- 2
blackstangt 4th wire on oxygen sensor harness. Fox 5.0 Mustang Tech 2
G oxygen sensor??? Fox 5.0 Mustang Tech 6
Blk91stang Checking Power to Oxygen Sensors?? How?? Fox 5.0 Mustang Tech 2
N Oxygen sensor question Fox 5.0 Mustang Tech 10
Quick Pony Oxygen Sensor Removal?? Fox 5.0 Mustang Tech 10
Chowder Head Does anyone have experience with this oxygen sensor kit? Fox 5.0 Mustang Tech 3
Quick Pony Oxygen Sensors ? Fox 5.0 Mustang Tech 3
chr1s11575stang Oxygen Sensors??? Fox 5.0 Mustang Tech 9
I Installed BBK longtube headers and engine runs better without oxygen sensors!!! Fox 5.0 Mustang Tech 8
Dean85GT Oxygen sensor bung thread size? Fox 5.0 Mustang Tech 2
P Oxygen Sensor Wires Backwards? Classic Mustang Specific Tech 3
stevesLX oxygen sensor wiring Fox 5.0 Mustang Tech 6
F Oxygen Sensor Signal Wire Fox 5.0 Mustang Tech 5
