  • 1994 - 1995 Specific Tech
P-Head review
  • Thread starter Thread starter timk
  • Start date Start date Mar 21, 2004
First Prev 2 of 2
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 1, 2004
#21
  • Nov 1, 2004
  • #21
TMC said:
Sweet...so you got it back on the dyno with some additional tuning since the 257 pull? Looks like a 20 HP and 20 TQ gain, well done!
Yes I did Troy. I'm awaiting some Jim Miller 1.70 rockers and a full-load adjustable push rod and I'm gonna get the valve train set up just right this winter and redyno next spring. We'll see how much the vavle train "blue printing" and the 1.70 rockers are worth.
shewitt
85
Newnan GA
Nov 1, 2004
#22
  • Nov 1, 2004
  • #22
from what i have read that it wasent a good idea to go with 1.7 with p heads
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 1, 2004
#23
  • Nov 1, 2004
  • #23
It's not that it is a "bad" idea, the flow on the stock P heads levels off around .400" lift and stays pretty even to .600" lift. Putting higher ratio roller rockers can gain some effective duration (at the valve) if you can take advantage of it, and my heads might be able to since they have valve seat depths and undercut valve stems - I'm gonna see. Also, if the geometery can be improved you can see a gain also. This is my final step in trying to optimize this setup.
95snoozer
2,572
RCR
Nov 1, 2004
#24
  • Nov 1, 2004
  • #24
where did your Ps peak at and hopw far did they pull to?
i am going to spin these bad boys up as high as i can go
95snoozer
2,572
RCR
Nov 1, 2004
#25
  • Nov 1, 2004
  • #25
Killercanary said:
I LOVE the GT40P heads, I mean what is there not to like. If I knew I could run them with a turbo (I'm worried about the header clearance issues) I would put them on my '90GT turbo project.
my friend ran a turbo kit on his fully ported p heads
i forget which kit though
I think it mah have used flipped p shorty headers
Killercanary
The car that set the bar.
Altoona, PA
Nov 1, 2004
#26
  • Nov 1, 2004
  • #26
REALLY?!?! That's GREAT to hear. I just didn't know for packaging reasons if it would fit with the P specific headers and the turbo. Thanks!
P.S.- did you upgrade your valve springs on your P heads since you plan to rev it?
tmoss
Gettin Wired
7,153
32
128
Saint Louis, MO
Nov 1, 2004
#27
  • Nov 1, 2004
  • #27
My torque peaked at ~4,000 rpm and HP peaked at 4,800 rpm and held flat to 5,400 rpm.
OrangeMustangGt
1,976
Cape Cod, MA
Nov 1, 2004
#28
  • Nov 1, 2004
  • #28
woah, damn i guess that just shows the potential my combo may have., when it s tuned
shewitt
85
Newnan GA
Nov 1, 2004
#29
  • Nov 1, 2004
  • #29
Im installing a novi 1000 now so i hope i dont have any problems from the heads some people say p heads are no good for superchargers
95snoozer
2,572
RCR
Nov 1, 2004
#30
  • Nov 1, 2004
  • #30
I have some comp doubles with new locks and retainers, or I will run the oens that are on teh e7s right now.
oddly enough i ran into my friend with the turbo car today. fully portedps with ferra valves he will be selling when his afr 185s are done.
I will ask him what kit he has on wednseday in economics class
95snoozer
2,572
RCR
Nov 1, 2004
#31
  • Nov 1, 2004
  • #31
thats bull you will make more power with less boost because of the higher compression and it wont be as much of a dog on the low low end off boost driving due to the raised compression.
of course keep the tune safe so head gaskets are not an issue
shewitt
85
Newnan GA
Nov 1, 2004
#32
  • Nov 1, 2004
  • #32
ya i dont beat on the car that much but before the head change i could keep up with a vett now with this head change i was racing a rouch 03 or 04 and i could keep up with him and slowley pull away from him. The only thing was traction his tires were so big in the back he could hook up but when i did i would catch him
OrangeMustangGt
1,976
Cape Cod, MA
Nov 1, 2004
#33
  • Nov 1, 2004
  • #33
yeah, from what ive seen, with a correct tune, and supporting components, people are making comparable power numbers to alum heads!! now, this is with everything perfect, but damn for so cheap, you cant go wrong, and i guess ford really did try with threre last go on the 5.0 motor trying to get it to pass strict emmissions.
l.groves
133
Florida
Nov 1, 2004
#34
  • Nov 1, 2004
  • #34
The thing flat hauls with the cower cam and 1.7's. Just put a 70 TB on her a week ago and she now pulls great on the bottom and then the cam kicks in with my torque convertor at about 2500 and slaps you back in the seat until 5500 rpm. Still have a few issues as per my post earlier but over all very very satisfied with the P heads. Mine are a little modified though...
fiveotony
1,437
Gainesville, Ga
Nov 1, 2004
#35
  • Nov 1, 2004
  • #35
Since I grenaded my engine I am selling my P heads so I can up to the aluminum heads oddley enough I do not think the new heads will make that much of a difference from the old setup.
First Prev 2 of 2
Most ridiculous / dishonest work you have heard a shop recommend?
  • SchwarzStock
  • Jul 19, 2026
  • Off-Topic Hangout
Off-Topic Hangout Jul 20, 2026
SchwarzStock
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
