ok stock 94 bottom end. b cam, tf twisted wedge heads and fms 1.72 rr so should i have problems, i will use the modeling clay method, but i just wanted a prelimanary idea before i rip it apart. thanks
I know that Ford Racing recommends checking it with the E cam and the Y303 heads - less duration, and smaller valves than your combo (although the 2.02's not as bad in the tfs because of the configuration). It's close enough that you're doing the right thing by checking - and just be happy if you've got plenty of clearance.
