Engine " P0316" Engine Misfire First 1000 Revolutions.
Groundshaker
11
Still having problems with my 2002 GT 4.6 / computer notifications. Could the code (listed above) be a weak coil? I have been having problems with what I think is a clogged injector on bank (2). I have replaced a very clogged fuel filter. I have new bosch iridium spark plugs installed and ran some "Gumout" injector cleaner in the tank. It has been running worse now and the "check Engine soon" light came on. I just read it and got a different code from before (lean condition in bank #2). < that is the before code. Now it says misfire. This beautiful GT is becoming a money pit, and if I can't resolve this soon, I will sell it.
Just wondering. What have you done to rule out a loose CKP sensor?
How about the crank damper? Under drive pulleys? How was the crank damper torqued?
Another possibility is loose/worn timing chains.
If clogged injectors are suspected, consider a cleaning flow test service such as injectorRX.com.
I bought the car as listed. I have no idea how it was torqued. I am an old man that has let progress get way ahead of me. I have no idea what a CKP sensor is. I guess I should have bought the J code 68 coupe instead of the two 2002's . I could have worked on it with ease (I grew up with them). Thank you for the info. :nice:
How old are you anyway? Too old to learn? You must be young at heart if driving two 2002 GT Mustangs! I'm knocking on 60's door myself. So I suspect we are more similar than different. I grew up driving cars with carbs and points.
One of the differences in my case is a Ford reference library to study and learn from. If interested in getting a copy for yourself I maybe able to help. PM (that's private message) if interested.
A small investment in reference materials might save you 1,000's allowing you to keep the cars that you have and not spend $$ on an old car just because of being behind the learning curve. The new cars really are better in terms of safety/reliability if one is honest.
CKP = Crank shaft position sensor. This is the sensor that tells the PCM where in the rotation the crankshaft is. This lets the PCM know when to spark and to inject fuel. Think of it like a distributor/points/PIP (depending upon how far back you want to go).
IF the COP coil was weak, it would be weak all of the time not just in the first 1000 revolutions. In my experience this DTC code is usually associated with a motor base timing problem.
Hence one of the reasons I was asking about the crank sensor and crank damper. Note, sometimes cheap under drive pulleys can cause an unstable CKP sensor signal.
Always post the full DTC codes. There are 1,000's of them and they each have a story to tell.
But as an reminder. For a lean related DTC the odds favor a vacuum or exhaust leak.
I am 63. the 2nd stang is my wife's V6 rag top . I live in a mobile home park and working on cars is forbidden. So I have to have it repaired. the wife's car runs great and I have drained my account into the coupe. I am going to sell it and be done with it. It has a lot of great stuff in it (drilled and slotted rotors, perf clutch, borla s type exhaust, short throw shifter, wide cobra rims with nitto tires., ibach suspension +++) I will find a kid that will love to slalom this car and fix all its problems :). Thanks for the help .
As a parting point, This problem could be something as simple as a loose screw holding the CKP sensor to the block. A 5 minute fix including the time to get the tools out.
Nor did you answer the question if this car has under-drive pulleys. Often people "mod"ing their own cars focus on the $$'s when swapping parts. Cheap under drive pulleys or incorrectly installed crank damper pulleys can CAUSE an unstable CKP sensor signal. A stock crank damper is a $65 part with an hour of install time. So even if you have to pay to have the work done is cheaper than selling. And even if you still decide to sell, it will pull in more $$ if working as it should.
Precision Parts Powerbond OEM PB1516N - Harmonic Balancer | O'Reilly Auto Parts
What you could be experiencing is the "dark" side of user "modding". There really is a reason why Ford designed certain parts the way that they are. Poorly designed cold air kits that cause drive-ability problems. Already mentioned under drive pulleys and the problems they can cause.
Of course this car may have bigger issues such as worn timing chains. Someone out in Internet land could possibly know without more tests.
Sorry we couldn't bring you into working/fixing a modern car. Good luck to you.
