P0340 Camshaft Position Sensor circuit fault???
98blackstallion said:
Well it keeps causing the light to come on. I have a bad miss fire that i thought was the coil packs so i replaced them with MSD units but the miss fire is still there....So could this sensor be causing me to lose power and get a bad miss?
Answered...
svttech76 said:
without a working cam sensor the car can stall on quick throttle changes... it also can cause he pcm to go into batch fire mode for the injectors and ignition and this is not as efficent.
Try replacing the sensor...
