P0420 replaced O2 bank 1 came back on now what?
Jlattan75
10
Morgantown, wv
I replaced O2 sensor 1 bank 1 after about 100 miles check engine light was back with exact code. Currently I am running a Ford Racing dual exhaust cat back. Driver's side is loose at the brackets in the rear. It rattles a little. Could that cause a problem with O2 sensors? What do I need to do next? I've heard of actually checking the cat, looking for an exhaust leak, and possibly cleaning the MAF (which is on a Ford Racing intake)? Anybody have some suggestions?
Maybe try switching your 02 sensors with each other and take it for a test drive and see if it’s still running the some code.
I had this issue when I put in my long tube headers the 02 sensor welded it’s self to the header and I had to rethread it and figured well that was weird only after a day of driving it. Then switched it to the other side and I got a different code and sure enough it welded itself to that side as well. So went down to parts store bought a quality new one and issue was gone.
Now I know you said you just replaced one but maybe check it again. You could possibly have bought a faulty one/low quality. Or the heat cycles from the exhaust could have caused it to come loose to if it wasn’t tightened enough. Or retightened after the first few heat cycles
