p0453 code
I just replaced the fuel pump and filler neck grommet On my 2000 Mustang GT 4.6 liter .Now I'm getting a p0453 evap pressure sensor is indicating a higher than normal pressure. I found the plug at the back of the fuel tank and cleaned the pins on the plug but I'm still getting the code. What else can I try?
Do you have an ODB2 scanner? It would help the trouble shooting to know what the PCM "thinks" the FTP value is.
ForScan ODB2 scanner w ELM327 USB
P0453 - FTP Sensor Circuit High Voltage Detected
The PCM monitors the EVAP control system FTP sensor input signal to the PCM. The test fails when the signal average jumps above a minimum allowable calibrated parameter
FTP circuit open
VREF shorted to VPWR
Damaged PCM
FTP circuit shorted to VREF or VPWR
SIG RTN circuit open
Damaged FTP sensor
