  • SN95 4.6L Mustang Tech
P1132
  • Thread starter Thread starter m0squ1t0
  • Start date Start date Dec 25, 2011
M
m0squ1t0
103
  • Dec 25, 2011
My '01 GT vert has been running rough for a few days for I scanned for codes and got P1132 (Lack of Upstream Heated Oxygen Sensor...Bank No. 1) Crawled under the car to switch the sensor out and discover that I can't get to it. There's no way for me to actually get my hand in there. So what should I do? I need this changed out before Wednesday when I will be needing to drive the car quite a bit. Suggestions?
M
m0squ1t0
103
  • Dec 25, 2011
Anyone? 11 views and no ideas?
M
mustangjoe02
84
  • Dec 26, 2011
try your best. ive changed them before and its a p.i.t.a. to get ur hand to connect the wires but idk any tricks to it sorry
M
m0squ1t0
103
  • Dec 26, 2011
Thinking about lowering the passenger side of the exhaust..
97GTSTANG
852
Virginia
Dec 26, 2011
  • Dec 26, 2011
I had the same code, replaced front two o2 sensors and problem went away. its an hour worth of work at the mechanic and you dont have to worry about it. I watched mine removed and he had to use the torch to get them to loosen up. Well worth the $80 for the hour work.
  • Gulftown980x
  • Jul 29, 2026
squeak93
ECU help!
  • starkiller1134
  • Aug 16, 2025
SN95 4.6L Mustang Tech Aug 17, 2025
starkiller1134
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
A
Check Engine codes jumping around
  • azactor
  • Jan 9, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
DadLife0724
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
