  • SN95 4.6L Mustang Tech
P1443
  • Thread starter Thread starter VDunn
  • Start date Start date Aug 9, 2004
1 of 2 Next Last
VDunn
32
Louisville, KY
Aug 9, 2004
  • Aug 9, 2004
I need to know where the Canister Purge Solenoid is located. I went to Autozone and they pulled the code from my computer P1443. The troubleshooting tip was "Evaporative Emission Control System Control Value". Then I called Star Ford (Dealership) and they said it was the Canister Purge Solenoid. So I need to know where it can be found so i can change it.
R
Roger_4.6_96
1,209
Reno,NV
Aug 9, 2004
  • Aug 9, 2004
Its a Silver or Black Little Box with 3 hoses coming off of it. I attached a pic showing where it is. mine has been bad for 2 years it cost $79.99 from ford
M
MoNsTaMaCk24
742
Shippensburg, PA
Aug 10, 2004
  • Aug 10, 2004
He showed you the DPFE sensor...Purge one is on the other side of car... I threw 4 codes that was one... I spent too much to get it all fixed... I hate sensors... But the Purge canister should be on your passenger... It is a gray like thing in a black like wrapping... Mine was showing rust...
cmb91LX
432
Memphis
Aug 10, 2004
  • Aug 10, 2004
I have had that same code for years as well. Does it set the computer into "safe" mode at all?
VDunn
32
Louisville, KY
Aug 10, 2004
  • Aug 10, 2004
Alright well I need a pic if Roger_4.6_96 is wrong.
nyuk98gt
1,427
Chesterfield, MO
Aug 10, 2004
  • Aug 10, 2004
VDunn:
Look on the passenger's side near the firewall. You will find a solenoid with vacuum hoses attached (inlet and outlet) and an electrical connection on the bottom. The solenoid has a black rubber sleeve on it. There should be another vacuum/electrical switch near the center of the cowl, kind of near the weatherstripping along the firewall. Follow this vac hose to the left to find the purge solenoid. (The vac outlet of the solenoid goes to the firewall switch).
Sorry for the lengthy description. I hope it helps.
R
Roger_4.6_96
1,209
Reno,NV
Aug 10, 2004
  • Aug 10, 2004
Um... When i went to ford thats the sensor they showed me oh well f-uck helping people here too many know it all's.
VDunn
32
Louisville, KY
Aug 10, 2004
  • Aug 10, 2004
I think i found it.
VDunn
32
Louisville, KY
Aug 13, 2004
  • Aug 13, 2004
BUMP!!
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Aug 13, 2004
#10
  • Aug 13, 2004
  • #10
VDunn said:
I think i found it.
which one is which? looks like the 2nd pic is just the purge sensor. but which one in the first pic is the canistor?
9
99SCGT
KANSAS
Aug 13, 2004
#11
  • Aug 13, 2004
  • #11
ROGER 4.6 96 IS WRONG (SORRY FOR CORRECTING YOUR ERROR) RYSRED PHOTOS SHOW THE CORRECT SENSOR. I HAVE NOT SEEN THAT SENSOR GO BAD VERY OFTEN. I SELL FOR PARTS AND WORKED ON FORDS FOR FOUR YEARS.
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Aug 13, 2004
#12
  • Aug 13, 2004
  • #12
but which one's which?
M
MoNsTaMaCk24
742
Shippensburg, PA
Aug 13, 2004
#13
  • Aug 13, 2004
  • #13
here is a secret... I replaced the one in the second photo cause "someone" said that was it... Well few days later CHECK ENGINE is back same code... Try the one in the middle!
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Aug 14, 2004
#14
  • Aug 14, 2004
  • #14
if you're having idle problems and slight surging, then it's the canistor or purge valve. if you're idle is normal, then its the sensor. mine had no idle problems and it was the sensor.
M
MoNsTaMaCk24
742
Shippensburg, PA
Aug 14, 2004
#15
  • Aug 14, 2004
  • #15
How much is the sensor? Ford the only place to buy it???
RysRed96GT
I like it FURRY!!!
3,207
Pasadena, MD
Aug 14, 2004
#16
  • Aug 14, 2004
  • #16
less than 20 bucks. and im pretty sure its a ford only part.
nyuk98gt
1,427
Chesterfield, MO
Aug 15, 2004
#17
  • Aug 15, 2004
  • #17
Roger_4.6_96: Nobody said you were wrong. It is entirely possible that the Ford guy gave VDunn the wrong info. He's just trying to get a problem sorted out. No harm/foul intended.
Chris
nyuk98gt
1,427
Chesterfield, MO
Aug 15, 2004
#18
  • Aug 15, 2004
  • #18
VDunn:
Yes, the top pic is the solenoid and the bottom pic is the switch that the PCM controls (on/off) to make the solenoid work.
You can check the solenoid by putting a handheld vac pump on the outlet (the end towards the upper plenum/throttle body area). It must hold vacuum for more than 30 seconds. If it doesn't, replace it. If it holds vacuum, apply 12 V to the electrical connection and the solenoid should click open. With vacuum applied and then 12 V applied, the solenoid will open and the vacuum will drop to zero. If the solenoid does not work, replace it.
Hope this helps.
Chris
VDunn
32
Louisville, KY
Aug 16, 2004
#19
  • Aug 16, 2004
  • #19
would the solenoid make the car run weird. The car seems to lag a take off and it virbates at the stop light. The virbation can't be from the transmission because it just has been rebuilt.
ElectricTang
663
Roanoke,VA
Aug 16, 2004
#20
  • Aug 16, 2004
  • #20
My check engine light was on for about 8 months because of P1443 before I did anything about it. I never saw any differenece at all in how the car ran during that time. I first replaced the sensor, the one in the second pic with the solid black tube connecting on one side and the black tube with red stripe connecting on the other. My check engine light stayed off for about a month then came back on. I then replaced the cannister/solenoid and havent had the code since. Heres the part #'s the sensor was like 15 bucks and the cannister was around 50.
Purge Flow Sensor Part # F57Z-14A606-BA
Purge Flow Cannister/Solenoid Part # E4ZF-9C915-AA
1 of 2 Next Last
R
Engine Evap and charcoal cannister leak
  • ryan1994stang
  • Mar 14, 2026
Fox 5.0 Mustang Tech Mar 18, 2026
Mcmahst
A
Resolved 03 GT Parasitic Draw Fuse 26 (PCM)
  • Antrix
  • Mar 22, 2025
SN95 4.6L Mustang Tech Mar 24, 2025
89ripper
07 v6 4.0 wiring issue .In desperate need of help.
  • Staycstang
  • Sep 19, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Sep 19, 2025
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
