P1443
VDunn
32
Louisville, KY
I need to know where the Canister Purge Solenoid is located. I went to Autozone and they pulled the code from my computer P1443. The troubleshooting tip was "Evaporative Emission Control System Control Value". Then I called Star Ford (Dealership) and they said it was the Canister Purge Solenoid. So I need to know where it can be found so i can change it. :shrug:
Its a Silver or Black Little Box with 3 hoses coming off of it. I attached a pic showing where it is. :nice: mine has been bad for 2 years :shrug: it cost $79.99 from ford :notnice:
He showed you the DPFE sensor...Purge one is on the other side of car... I threw 4 codes that was one... I spent too much to get it all fixed... I hate sensors... But the Purge canister should be on your passenger... It is a gray like thing in a black like wrapping... Mine was showing rust...
VDunn:
Look on the passenger's side near the firewall. You will find a solenoid with vacuum hoses attached (inlet and outlet) and an electrical connection on the bottom. The solenoid has a black rubber sleeve on it. There should be another vacuum/electrical switch near the center of the cowl, kind of near the weatherstripping along the firewall. Follow this vac hose to the left to find the purge solenoid. (The vac outlet of the solenoid goes to the firewall switch).
Sorry for the lengthy description. I hope it helps.
I think i found it.
ROGER 4.6 96 IS WRONG (SORRY FOR CORRECTING YOUR ERROR) RYSRED PHOTOS SHOW THE CORRECT SENSOR. I HAVE NOT SEEN THAT SENSOR GO BAD VERY OFTEN. I SELL FOR PARTS AND WORKED ON FORDS FOR FOUR YEARS.
Roger_4.6_96 said:
Um... When i went to ford thats the sensor they showed me :rolleyes: oh well f-uck helping people here too many know it all's.
Roger_4.6_96: Nobody said you were wrong. It is entirely possible that the Ford guy gave VDunn the wrong info. He's just trying to get a problem sorted out. No harm/foul intended.
Chris
VDunn:
Yes, the top pic is the solenoid and the bottom pic is the switch that the PCM controls (on/off) to make the solenoid work.
You can check the solenoid by putting a handheld vac pump on the outlet (the end towards the upper plenum/throttle body area). It must hold vacuum for more than 30 seconds. If it doesn't, replace it. If it holds vacuum, apply 12 V to the electrical connection and the solenoid should click open. With vacuum applied and then 12 V applied, the solenoid will open and the vacuum will drop to zero. If the solenoid does not work, replace it.
Hope this helps.
Chris
My check engine light was on for about 8 months because of P1443 before I did anything about it. I never saw any differenece at all in how the car ran during that time. I first replaced the sensor, the one in the second pic with the solid black tube connecting on one side and the black tube with red stripe connecting on the other. My check engine light stayed off for about a month then came back on. I then replaced the cannister/solenoid and havent had the code since. Heres the part #'s the sensor was like 15 bucks and the cannister was around 50.
Purge Flow Sensor Part # F57Z-14A606-BA
Purge Flow Cannister/Solenoid Part # E4ZF-9C915-AA
