Hey guys. Just the other day my cel came on. I had the code scanned and found the p1445 code in there twice. Not sure why it came up twice. Had it cleared and it came up twice again. I looked the code up and it says the Purge Flow Sensor circuit Input is High. I searched and found that it might be the fuel filter, might be the Purge Control Solenoid or Purge Control Valve, might have something to do with the front 02 sensors, and might have something to do with the timing. Figured I might be able to get a straight answer from someone else. The car actually drives perfectly fine. No problems anywhere. Idle's fine, pulls fine under full throttle. I want to fix the problem before something more serious comes up. So if anyone could help me out, I would greatly appreciate it. Thanks a lot.
Brian
Brian
