Here's the info I used:
I got my first 3G from a '94 Mustang GT (130A) which had the same 7" between the mount holes. The Taurus Alt has 8 1/2", which requires the mod to the lower mounting bracket.
I have my battery in the trunk, so I put the 150A fuse back there.
I also ran the yellow/white sense wire back there to get the voltage at the battery to make up for any voltage drop through the 4 gauge charge wire.
Q: Where do I crimp the green/red wire that comes in the kit?
A: The green/black wire goes to ignition power with a slight resistance to simulate the alt lamp. You can use your existing lamp or just go to Radio Shack and get around a 560 ohm resistor.
You can remove your existing external voltage regulator box, as the 3G is internaly regulated. You can tie the white feild wire and the green/red wires together there and use the white wire in your alternator harness to crimp to the green/red wire from the kit. you can put the resistor in any where along the path.
Q: Where do I install the stock ground wires from the stock alternator harness?
A: My alternator is grounded from the case to the engine block by the mounting bolt only. You can remove them or tape them up. Just make sure you have a good ground from the battery to the engine.
Q: Do I install the stock hot wires at the B+ terminal under the big fat positive cable they supply?
A: Yes
Q: Is the stock field wire used?
A: No, see above
The diagram below should help:
