  • 1994 - 1995 Specific Tech
Paging KillerCanary
  • Thread starter Thread starter sc95gt
  • Start date Start date Oct 10, 2004
sc95gt
23
  • Oct 10, 2004
Just wanted some final advice on indexing my belhousing...
I've had a 3550 in my car for almost 2 years, but driven it very little as I have experienced the 70 mph vibration you have described.
I recently swapped the SROD bellhousing I had originally installed with a used Motorsports bell (part # used on the '95 Cobra R).
After the bell swap, shifting was noticably improved and the tranny whine disappeared, but the vibration is still present.
This weekend, I swapped the 3550 for a T5 that my neighbor was kind enough to lend me. The T5 is smooth as silk...
Anyway, the final question is whether or not it is possible to index the Motorsports bell? Do I use the Lakewood offset pins?
As I need to return the T5 to my neighbor, I will have an opportinity to check the Motorsports bell alignment. Hopefully I will find that it is out of spec - if not I think that I am going to give up on the 3550 and trade someone for a T5...
Thanks!
Killercanary
The car that set the bar.
Altoona, PA
Oct 10, 2004
  • Oct 10, 2004
Its definitely possible to index the motorsports bell housing. If you find it is NOT within spec, you will need to buy the lakewood offset dowel pins, I got mine from Summitt. Your bell must be no more than 5 thousandths out. Do you know how to do it?
badingle
127
Portage, Michigan
Oct 10, 2004
  • Oct 10, 2004
Paul- youve got mail
-Andy
sc95gt
23
  • Oct 11, 2004
Paul,
I ahve read the write up, but am not sure about attaching the dial indicator with a magnetic base to the flywheel. How do you simply guess where the center of the flywheel is located? I assume that the 4 measurements will eliminate any centering error...
Thanks for the reply - congrats on the write up!
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fox New to me 82 GT
  • Stangman7082
  • Jan 20, 2025
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 18, 2025
AeroCoupe
Drivetrain Bellhousing runout alignment
  • Sparky714
  • Jan 1, 2022
5K
Fox 5.0 Mustang Tech Jan 1, 2022
Sparky714
