PAINT HELP!
  • Thread starter Thread starter Nightstalker5.0
  • Start date Start date Apr 10, 2004
N
Nightstalker5.0
10
  • Apr 10, 2004
87gt is stripped down to the origanal primer, windows, moldings all removed, getting ready for paint, First time painting need all the tips i can get. Whats the best grit to run the entire body over with before primer? What type of primer? i want a primer that is think so i can go over any light high and low spots with it, its reffered to as spray on bondo its so think? how do i prep the bumpers and ground effects? how many coats of base and what kind of paint?, how many coats of clear? any tips would be greatly apprecited. Jut
Anyone have any ground effects brakcets for sale, need all of them? NVSEALs07@aol.com
1986LX2002
317
  • Apr 10, 2004
If its down to primer, wet sand the car with 600grit. you only want to smooth the car down to wear you dont feel any rough spots. I totally redid my 86 GT from the ground up and repainted it myself too. As far as primer I just used some PPG primer and for the bumpers I used flexible urethane primer. For coats I have 3 color coats with 2 coats of clear. For best results Wet sand each coat with 600grit sandpaper you'll get a great shine to it. I didnt wet sand my last coat of clear though! Heres a link for the post I just did. I did this car from the ground up!! keep that in mind and did all my body work and paint myself. And i'm only 20 years old and never took shop class or body class.
http://forums.stangnet.com/showthread.php?t=449489
Paint and Body What to use to clean up/prep painted surfaces before painting
  • AnthonyA1234
  • Sep 27, 2024
Fox 5.0 Mustang Tech Sep 28, 2024
limp
Paint and Body How can I paint this antenna base?
  • AnthonyA1234
  • Sep 17, 2024
Fox 5.0 Mustang Tech Sep 20, 2024
AnthonyA1234
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
