Painted supercharger, anyone? pics?
Depends on what paint you use really. Some paints let heat escape more readily than others.
polishing the part creates more heat soak because the heat transfer from polished surface to air is greater. Painted parts keep the heat inside, so there is less relative heat soak to parts nearby.
You kinda gotta look at it on a part by part basis. If you polish a part, will it heat soak your entire bay? If you paint a part, will the trapped heat cause any issues?
