painting pillar pod
First thing you need to do is find the correct shade of tan from a chip book of your local paint supplier. there are several shades of the same int color(ex. '91 ford code p is smoke and dk smoke,same letter on door but 2 diff colors and 2 more gloss levels). wipe pod off w/hot soapy water and rinse. spray sem plastic prep,part # 38353, on and wipe off. Next, get a grey 3m scuff pad and very lightly scuff pod. Respray w/plastic prep and dry 1 direction. Excessive wiping causes static. Spray 2 coats of Klean Strip Bulldog #PO123 and spray int color on within 10 min. I would recommend using the 5 degree gloss version of int color. If it is too dull you can always put something on it to shine it up. But if it's too shiny the glare will be annoying. We put high quality int paint in aero cans all the time so you should be able to find someone local.Hope that helps.Lee
