painting calipers
It's Easy
I went to Pep Boys and bought caliper paint and a can of carb cleaner. Then I sprayed the caliper to get all the grease etc. off. Sanded them for good measure. Sprayed again and wiped down. Then I masked everything off real good using newspaper so there would be no overspray on the other parts. It takes time to do the masking, but take your time. Then I heated the caliper with a hair dryer to warm it up and sprayed my first light coat. I dryed each coat with the hair dryer. I did this four times on each caliper. They look like glass and have held up perfectly. Expect to spend a good part of the day doing this and you have to do it in a garage out of the cold. Good Luck
:flag:
:flag:
i got the g2 kit off eBay and it came with the paint, brush, brake cleaner and everything else you need. let me know if you like it!
Here are pics of mine. Painted them with three coats of PlastiKote ceramic engine paint from AutoZone. I accidentally got a little overspray on one of the rotors and one of the shocks, but that's just better rust protection from the salt. :p
spend the time to mask off stuff it looks odd when the pads are painted
