I made a new thread that has ALL of the steps that we follow over at my body shop. It is very detailed, and you will most likely be SUCCESSFUL if you follow them, using your brain and being gentle with the paint. I hope that the step by step helps you and Anyone else that needs it. GOOD LUCK WITH YOUR PAINT -
If I only knew engines as good as I knew paint. My experience is about 6 years of doing this every day, not always to an entire car, some times just a few panels, or a side, etc.. but I follow this procedure to the TEE every single day except sundays of my life. And i've developed my own methods of speed and working the buffer, as will you. GOOD LUCK AGAIN !!!
