Should I paint the side mirrors and door handles the same as the exteriour of the car?? or Paint them the same as the window trim!? They're both gunna be black, but the window trim will be a bit different, since im using spray paint on it.
criticman said:Just make sure you have plenty of painter's tape (blue tape - masking tape would probably work just as well) and newspaper...and cover more area than you think you should because a slight breeze can make a mess on your car in no time.
StreetDreamsGT said:Why not just take the mirrors off to paint it? I'm sure it's harder to pull the door handles off than the mirrors but, why not just take em all off n paint em off tha car to be safe? As you said a slight breeze can make a mess on your car in no time, why not do it the right way instead of the easy way?
criticman said:Well, what may be the "right way" for you wasn't for me at the time. I was painting a lot of other areas (side molding, rear letters) at the same time and since I was going to have to tape off other areas, doing it for the mirrors made sense and worked just fine. So for me, it was both the right way and easy way.
hemi_fan said:how do you take off the rear-view mirrors?
