  • 2005 - 2009 Specific Tech
parking brake
  • Thread starter Thread starter zoop66
  • Start date Start date Dec 12, 2006
Z
zoop66
  • Dec 12, 2006
All of you in cold weather states be weary of the parking brake freezing up. My 05 with 17k just froze the other day, 15 degrees out. It was not a problem last winter but the dealer states that he has replaced two this year.
adj86
66
Dallas, TX
Dec 12, 2006
  • Dec 12, 2006
Yeah mine did it the other day after i washed my car. I didn't realize that the temp was going to get below freezing and stay there most of the day. If your parking brake does freeze don't get it towed go get a blow drier and heat the brake calipers on the rear wheels, takes about 20 minutes total. It worked for me. Only problem is i can't get it fixed under warranty i got 36500 miles on the car, sucks i know.
T
TGJ
1,049
  • Dec 12, 2006
There is a TSB out there on this. I am not sure this is a warranty issue or not, but I would fight it with the dealership that it should be covered. The fix is updated brake lines for the parking brake. What causes this to happen is moisture got in the current parking brake lines and froze making your parking brake stick. Had this happen to me before I put the car away.
GOLDENPONY
1,503
LOVELAND, OHIO
Dec 13, 2006
  • Dec 13, 2006
E-Brakes
I just had the same problem on my '06 GT 'vert. Dealer installed new cables under warranty.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Dec 13, 2006
  • Dec 13, 2006
dealer replaced my cables because they are idiots. they tried to fix one problem and assumed they knew what it was without looking into it.
on the plus side, they have not froze at all.
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Dec 13, 2006
  • Dec 13, 2006
i just had to put cables and rear calipers in a 2005 v6 the other day.. I did the cables and it still hung up.
Brake Fluid shelf life?
  • Bullitt347
  • Sep 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 29, 2026
nickyb
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
Hello from Washington State!
  • Daddys Lil Filly
  • Jun 10, 2026
  • The Welcome Wagon
The Welcome Wagon Jun 10, 2026
Daddys Lil Filly
