part number for best fel pro head gasket?
The words "nitrous" and "Fel-Pro" should never be in the same sentance.....
Lol,just kinda,but seriouly? Hmm...plobably one of the lock-wire gaskets,or maybe thier new MLS gasket,but I dont know how it would compare to a more reputable gasket like a Cometic.
Also,the SCE Titan copper gaskets (they self seal,no sealer) work very nice.They have a stainless fire ring wedged in between the gasket surface,so it will seal better as pressure increases (till the head lifts,anyhow).
The 1101-1 should work fine, if you want to prep the deck and head surface look at the MLS gaskets PT# 1133. Just remember the MLS stlye gasket is not as forgiving if you get out of tune.
With a good tune a stock headgasket will hold just fine.....
Thats what im running now. . . i was going to go through and re-gasket the whole motor this winter while i have it out
thanks rick, i dont think i will waste money replacing the head gaskets then. . . . good! 100$ saved:nice:
Oh i was thinking about a problem i thought you said you had in another post about heading or pressurizing your cooling system. it sounded like head lift to me. odds are with your compression and the added compression with the nitrous i would go and get a really good set of head gaskets.
it was the radiator cap!!!!! Its the simple things that kill ya :D But it got me thinking about other "weak" spots
Modular2v said:
yeah. . . my compression is a little higher than that:D
I am running 10:1 w/ 100 shot. Hindsight is 20/20. I will never put a stock headgasket on a modded engine again. I know Rick says it should be fine, and who am I to argue, he has built more engines in a week than I have my whole life. But my point is I would rather spend $150 on headgaskets now and have more piece of mind than if I spent $50 on Headgaskets and end up having to tear it apart later.
My compression is around 11.2:1
bluevenom867 said:
...Also,the SCE Titan copper gaskets (they self seal,no sealer) work very nice.They have a stainless fire ring wedged in between the gasket surface,so it will seal better as pressure increases (till the head lifts,anyhow).
Not to contradict you, but, I'll take issue with that one. I installed a set of those onto a 331 with AFR heads and the moment the coolant level rose past the heads, it leaked like a sieve. And before you ask, yes, surfaces were freshly machined, clean, and perfect. Same goes for the gaskets themselves-perfect. Head surfaces had the o-ring installed in accordance with the instructions provided from SCE by a competent machine shop. Torq values on ARP studs were strictly adhered to with a quality torq wrench. SCE swore up and down that there was a change made to the gaskets, so we get a new set free of charge...still leaked. The heads ended up being removed and installed twice, and involved costly (edit: installation and) removal of o-rings (required by the gaskets) and heliarc welding of the head surface + resurfacing the heads before we went with FRPP A302's (same thing as Fel-Pro 1011-2) and had NO problems whatsoever...we didn't even get to start the damn thing until about two months had gone by because of jockeying with SCE about why their gaskets sucked like queer in a jailhouse.
My experience could easily be explained as statistical noise and two isolated incidents by the manufacturer. But after having all the issues with them, the owner of the car and I did our own research. Several reputable local engine builders told us that they wouldn't dare recommend copper gaskets for use on the street; furthermore, they had only used copper gaskets on dry blocked (no coolant) applications.
In hindsight, I'd recommened going with something like ROL hi-temp graphite gaskets, or something of the like.
Hmm,you had a bad experiance,probably your decks and head surface wasnt smooth enough.You need a very smooth head surface,40 or better RA if I remember correctly.
Also,I think your thinking of the wrong gaskets.The gaskets Im talking about do NOT use an O-ring,its a stainless fire ring that is wedged in the gasket surface around the cylinder bore area.
And,to prove it...Im runing them now.No problems.I didnt use any copper spray,no special break in insructions,and no leaks.
I have also used the Cometic MLS gaskets and they work very well.
