I moved my 85 2.3 l parts car to the driveway last week to see if it would run. The timing belt and dist seem to be right. I tried starting it, and with some starter fluid it fired a couple times, but no more. With the coil wire off at the coil, the coil arcs to the fender nicely, so it seems to have spark!
I checked the compression and got 60, 80, 30, and 80. With an air chuck in no 1 cylinder, supposedly at tdc, I get air blowing out the thermostat housing and dipstick. After this, I did not check to see if it had fuel in the carb even.
My guess is at least a blown head gasket.
Anyone else have suggestions?
Think it should run with that kind of compression?
I got it as a parts car, but now I'm wanting to get it running just to see if I can. Donation of a carbed 85 motor would be welcomed....
You would never get the smell out. As far as how far up im a little over 300 miles farther north than portland. Its a compleately different state up here
Well anyways good luck with you fox!
