Parts (mostly)from a 76 Ghia
car is gone.
I have a V8 C4 small bellhousing and a double hump crossmember still. I can ship the crossmember, not too sure about the bellhousing. I also don't know for sure about the bellhousing, I was told that was what it is.
If you are local to Northern Ohio I also have a radiator support with fender aprons. The aprons were cut just above the spot weld points, and along the firewall. Probably best for patching. Only bad area is the battery tray area-that was cut out and a sheet metal patch put on. None of this was by me.
Best bet is to email me, I pretty much forgot about this ad.
[email protected]
Russ
