Well, my friend who had the car before me locked his keys in once and got a sheriff to use a slim jim to get it open, but he broke the lock cable on the passnenger side. What all will I need to fix this and how hard is it?
The sheriff probably broke the plastic clip that's attached to the lock itself. The only place I know of to get that plastic piece is at a junkyard. that's where I got mine.The Green GT said:Well, my friend who had the car before me locked his keys in once and got a sheriff to use a slim jim to get it open, but he broke the lock cable on the passnenger side. What all will I need to fix this and how hard is it?
HISSIN50 said:I think Chythar is right on the money. Without that plastic cone, the linkage can pop out.
I kinda doubt the design changed from foxes to 5N95's, so perhaps a resto shop (LRS, et al) might have them too. If they do, it should be like a buck.
Really you could/should remove the panel first to see what gives, since you and we are just guessing. You could probably temporarily rig the linkage together if you are in there.
Good luck.
HISSIN50 said:Thanks for pointing out the lock retainer differences. My eyes are so bad I cant make out the plastic retainers in the pics. I thought the 94+ had the one piece like you said. But when I swapped them on my fox, I thought it was a one piece unit too.
I'm sure you are right - my memory is just bad.
Good idea from Scott with using the dealer (their mark-up should offset shipping. ).
Scott, I have rigged mine too. How about 'fine tuning' the door release by bending or straightening the long linkages a little.
The Green GT said:This wouldt happen to be the clip you guys are talking about huh? When I was doing the body work on my car I was at a Ford dealership and i was looking for for push clips and I saw a box that said something like "lock cable clips" so I grabbed a few.
