When I bought my Vert. the pass. window control did not work but the main panel did so it was no big deal. I have tried several things to repair it, replaced the module, made sure master window lock not on, traced wire to door panel, but no luck so far. I should mention that the door lock on the pass. does work so power is not the problem. I took the main driver's side panel out to check it out and found a red wire with a blue strip not hooked to anything. It had a piece of tape on it as well and I can't seem to figure out what its for. Everything on the door works so I was wondering if this is the problem.
In the picture the mystery wire is to the left of the center. Sorry, I need to find a program to put arrows in. Any ideas?
http://www.cardomain.com/member_pages/show_image.pl?image=http://memimage.cardomain.net/member_images/11/web/2627000-2627999/2627100_5_full.jpg
