paxton novi 1000 on my car?
FSTRDNU
76
i have a e303 cam, ported/shaved/oversized intake valved e7's.
my motor is origional w/ 115k on it.
i trap at 108 in the 1/4
i am about to buy a car w/ a novi 1000 on it, and i would like to put the blower on my car.
will i be ok, it is building 7psi on his car.
i have a 93, w/ hyper pistons, will i be ok,
and his ecu id chipped, it is a 89, can i just take his ecu?
Should be fine. Swapping processors is easy enough, or if you'd like you can just swap the chip to your processor.... It'd be good for a base tune, but no two cars are the same and you will need to have it professionally retuned.
Nick
Hope you're not buying the car just for the blower. If so, I hope it's real damn cheap.
I've had a Novi 1k for about 3 years now (bought when first came out) and I hate it. Step up to a 2K or go kenne belle. With just a few mods you've probably already outgrown the output of the blower. I got a somewhat similar setup to you and I barely lay down 6-8 pounds of boost.
[edit] I take that back, you're putting down a bit more power than I was when I bolted mine on. Think I was running 105 in the 1/4. From the stock blower, I've added around 500 dollars worth of mods to the blower to get the boost I'm getting. I'm thinking you're going to be pushing 6# max with a 1k.
