Paxton Supercharger + accessory drive belt issue?
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Hi all, I'm having an issue with the accessory drive. This is for an 86 GT with smog and no AC (factory). Previous owner removed the anchor pin from the tensioner and installed it upwards so the belt was routed ABOVE the pulley not below it. I have to admit I didn't have an issue with it this way, at least not mechanically but the belt wasn't routed properly as it was rubbing on the alternator plastic shield and a little on the tensioner itself.
So being the fool that I am, I got a new belt and routed it properly. Much like the middle row, right column as illustrated below. I got the stock 86" belt (according to part source anyway). The belt was tight to put on, not much slack. But I also put the tensioner where it should be, pushing down on the belt not pulling up.
My issue is: There's very little room where the belt "meets itself" above the water pump and tensioner pulley. I have about 1/4" between that area. With that being the case, I can't load the belt like it normally would, the tension indicator is at zero. :( The thing is, I can't really move the power steering by hand, nor can I move the alternator or smog. The water pump however I can move it clockwise (not super easy) but I can't move it counter-clockwise.
:shrug:
looks almost as bad as this:
Here's what it used to look like:
74256d1247787498-1995-mustang-gt-air-pump-delete-after-o-r-x-pipe-1sptech_50belts.gif
Many thanks
  • 74256d1247787498-1995-mustang-gt-air-pump-delete-after-o-r-x-pipe-1sptech_50belts.gif
i just put a vortech on and had the same problem, you need to space the alternator stay bracket down. I put washers inbetween the smog pump and the alternator stay you will also need a longer bolt.when you do this it will move the alternator down putting more tension on the belt, the more washers the more tension. hope this helps
Cool! Thanks man, that helps, I'll play with that later. I figured out the kit was first designed for cars with AC, at least from what I gather on various message boards.
