Paxton
  • Thread starter Thread starter JT929240
  • Start date Start date Jul 17, 2010
  • 3
1 of 3 Next Last
J
JT929240
54
  • Jul 17, 2010
I found a guy selling a novi2000 he said he blew his head gasket and then his motor could this have damaged the blower he had it on a 91 GT????
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 18, 2010
  • Jul 18, 2010
depends how long it was driven with the blown gasket and if water made it thru the head unit. I blew two headgaskets with myne, but the car was driven for mabye 5 minutes combined with them being blown and it didnt hurt anything. But i cant see coolant being good for the bearings inside the charger
2000xp8
SN Certified Technician
Aug 8, 2003
8,061
1,646
194
NJ
Jul 18, 2010
  • Jul 18, 2010
Call and see how much a rebuild is, and then factor the cost into your negotiating price.
Just understand that a vortech SC kit is only $1800 new.
J
JT929240
54
  • Jul 18, 2010
Yea but the vortech kit only puts out like 5psi this guy said he was running 12psi..Also he said their is a chip that comes with it i think its like a mass air flow he said its probably in the wheel well but he doesnt know if he has it are these chip expensive to get from paxton? He says he wants 1400 do u think thats a good deal?
2000xp8
Aug 8, 2003
8,061
1,646
194
NJ
Jul 18, 2010
  • Jul 18, 2010
A vortech kit is a pulley away from 12 psi. Also remember boost has more to do with it than just how the kit comes, a combo with great heads will always make less boost.
A chip for his car has nothing to do with a chip for your car.
$1400, no way. I'd rather have new stuff. $1000, maybe.
J
JT929240
54
  • Jul 18, 2010
So if i buy a vortech kit that puts out 5-6psi all i have to change is the pull to get 12psi..So why do the kits jump from $1800 for the 5-6psi to #3000 for a 10-12psi kit i dont get it???
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jul 18, 2010
  • Jul 18, 2010
yeah but a Si-trim and a novi2000 are 2 very different blowers
J
JT929240
54
  • Jul 19, 2010
What is the difference between the two?
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 19, 2010
  • Jul 19, 2010
the novi is closer to a T-trim then an S-trim, bigger head unit. $1400 is a pretty screamin deal. If the blower is good i would jump on it quick, but definitly find out how long it was driven with a blown gasket.
From what ive seen, used novi's go for between 2000 and 2500. I paid 2400 for myne, used it for two years, and sold it for 2200 i think
J
JT929240
54
#10
  • Jul 19, 2010
  • #10
so when i look at the blower how can i tell if its in bad shape? Also the s-trim smaller head unit what max psi can it put out?
2000xp8
Aug 8, 2003
8,061
1,646
194
NJ
Jul 19, 2010
#11
  • Jul 19, 2010
  • #11
You probably aren't going to be able to tell anything by looking at it.
Used Superchargers are a crapshoot.
You could get one that lasts forever or one that lasts 2 weeks.
PSI number depends on your setup.
I can tell you this, the vortech S kit is powerful enough to split a stock block with the right h/c/i.
What's the setup you are running now?
IMO, used is a last resort, the warranty means alot considering a rebuild starts at about $500 and goes up from there.
The novi 2000 is more powerful than an S, but if you aren't going to put the extra power to use and don't have a setup to take advantage of it, i don't see the point.
J
JT929240
54
#12
  • Jul 19, 2010
  • #12
i tried to attach pics of the supecharger dont know if it worked but as far as my set up i have a 5.0 xxx block and changed all the internals i have a forged 4340 eagle crank keith black pistons and rods and gt40p heads with bigger valves just had them machined cost me $500 and aluminum rocker arms msd ignition cobra upper and lower intake and electric fan and 355 gears...so what do you think how much boost could i run on it? Oh and 42lb injectors and 255 fuel pump
J
JT929240
54
#13
  • Jul 20, 2010
  • #13
are stock 302 blocks really that weak do they crack if you run 12 psi on a supercharger?
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jul 20, 2010
#14
  • Jul 20, 2010
  • #14
that thing looks beat, i'd walk
2000xp8
Aug 8, 2003
8,061
1,646
194
NJ
Jul 21, 2010
#15
  • Jul 21, 2010
  • #15
450rwhp is about where you should take it.
Ya, you can push it to 500rwhp even 525rwhp, but then you go into the borrowed time category.
A vortech SC kit with a few upgrades easily eclipses 450rwhp.
Expensive internals really don't change much when using a stock block.
I agree with crane, that looks to have come off a car that was driven hard.
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Jul 21, 2010
#16
  • Jul 21, 2010
  • #16
x3 on the pass, that thing looks hammered, and it looks like its leaking oil too, you can find one alot better than that for a good price
J
JT929240
54
#17
  • Jul 21, 2010
  • #17
how much psi would a vortech sc put out and how much psi would i have to run to get 450hp i would be happy with that...and what other upgrades are you suggesting?
J
JT929240
54
#18
  • Jul 21, 2010
  • #18
also does anyone know about these main cap girdles i had seen them on summit racing website are these gonna strenghen the block at all or will it still crack if there was too much boost? i also seen a guy on ebay selling 302 blocks in nj that he reconditions and makes stronger this is his add.......................................................................................................................................................................................................................HERE IS AN AWSOME PRICE ON A COMPLETLY CNC MACHINED LATE MODEL SMALL BLOCK FORD 302 ENGINE BLOCK. YOU WILL NOT FIND A BETTER PRICE OR BETTER QUALITY FOR THIS BLOCK ANY WHERE! THIS BLOCK SAFTELY HANDLES 600-625 HP. WE HAVE CUSTOMERS RUNNUNG THIS BLOCK FOR OVER 2 SEASONS WITH NO BLOCK FAILURES. WHAT MAKES THIS BLOCK SO MUCH STRONGER THAN A STOCK 302 BLOCK IS THE BILLIT STEEL MAIN CAPS THAT SPAN FROM PAN RAIL TO PAN RAIL. THIS TIES AND STIFFENS THE COMPLETE BOTTOM END OF THE BLOCK. THIS BLOCK IS READY FOR ASSEMBLY WHEN YOU CUT THE SHRINK WRAP. Do you think its true?
2000xp8
Aug 8, 2003
8,061
1,646
194
NJ
Jul 22, 2010
#19
  • Jul 22, 2010
  • #19
Girdles do nothing. Basically just false advertising.
As far as how much boost, each setup is different.
Boost is pretty much just a measure of pressure. So the more free flowing your engine is, the less boost an SC is going to make.
gbranton
402
Mobile, Alabama
Jul 22, 2010
#20
  • Jul 22, 2010
  • #20
I wouldn't trust someone who can't spell the word "billet".
  • 3
1 of 3 Next Last
C
Paxton novi 1200SL
  • Cambo617
  • Oct 9, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Oct 9, 2025
Cambo617
C
ECU/PCM ISSUE
  • Santi1015
  • Jun 29, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 29, 2026
Santi1015
Bought a 2001 GT from My Son
  • Hawkester
  • Oct 17, 2025
  • The Welcome Wagon
The Welcome Wagon Oct 17, 2025
gkomo
Rear quarter window regulator
  • BADAZZOMBIE08
  • Mar 29, 2026
2005 - 2009 Specific Tech Mar 29, 2026
BADAZZOMBIE08
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
