  • 1994 - 1995 Specific Tech
pcv + blower = high idle ...
  • Thread starter Thread starter BlackVert
  • Start date Start date Feb 1, 2006
BlackVert
5,589
9
98
Bethesda, MD
Feb 1, 2006
  • Feb 1, 2006
i am becoming more and more convinced that my blower is sucking hard enough even at idle that it is getting air through the valve cover vent and up through the pcv. i believe that this is causing 2 problems:
1. oil getting sucked into the intake.
2. idle too high.
to test this theory, i completely blocked of the iac and it still idled. i could feel air getting sucked in through the valve cover vent. then i vented the pcv to the atmosphere and blocked off the port the pcv tube was connected to. sure enough, the idle went to 800, right where i told it to be.
i believe this proves my theory, but is there another test i can do to prove it another way?
i would love to just leave it that way (pcv vented to the atmosphere), but i am worried that there will be too much crankcase pressure and the oil will come through the valve cover gasgets again.
i'm considering trying to find or break a pcv valve such that it is always open. then i can vent it to the atmosphere, and any crankcase pressure caused by the blower should be free to escape which would solve the above worry about too much crankcase pressure.
what would you do?
BlackVert
5,589
9
98
Bethesda, MD
Feb 2, 2006
  • Feb 2, 2006
ttt
95cobraguy
637
11
Concord, NC by way of LI, NY
Feb 2, 2006
  • Feb 2, 2006
are u using an oil separator?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Feb 2, 2006
  • Feb 2, 2006
2. idle too high.
what would you do?
I'll be the first to say I just don't know the answer
however
If what you say is true, all other KB combos do the same thing.
I don't remember seeing any other threads along these lines.
Grady
KBCobra95
356
North Carolina
Feb 3, 2006
  • Feb 3, 2006
Why not just mess with the idle screw?
BlackVert
5,589
9
98
Bethesda, MD
Feb 3, 2006
  • Feb 3, 2006
no, i don't have an oil seperator ... i should get an oil seperator.
that was the first thing i did, it didn't help.
then i disconnected the iac (the connector), still no help.
then i completely blocked off the iac with a piece solid plastic where the gasket goes. it was harder to start and the idle did go down, but it still idled.
then i disconnected the pcv and blocked off the vacuum inlet for it.
with the iac blocked off and the pcv valve disconnected, it would not start without opening the throttle a little. once it was running, it would almost die when i would close the throttle. it was clearly not getting enough air.
the i reconnected the pcv. and disconnected the valve cover vent, leaving it open. it started without having to open the throttle, like before.
i could feel the air getting sucked into the valve cover vent. when i blocked it off, the idle went down. when i took my finger off, it whistled for a few seconds (until it was caught up with the vacuum), then it stopped whistling but there was still air getting sucked in.
to me it really seems like enough air is coming through the valve cover vent and through the pcv keep me from being able to get it to idle below 1000.
maybe this is normal, but i would really like to be able to control my idle and set it to 800 if i want.
KBCobra95
356
North Carolina
Feb 3, 2006
  • Feb 3, 2006
Have you looked into the iac block off plates? The have smaller holes I believe and are may help work with your idle issues? I have a breather on mine so maybe you could try that?
DarkProphet
391
Quakertown, PA
Feb 3, 2006
  • Feb 3, 2006
Ive also heard of using a turbocoupe (i belive) PCV because they seal better, not sure though.
BlackVert
5,589
9
98
Bethesda, MD
Feb 3, 2006
  • Feb 3, 2006
KBCobra95 said:
Have you looked into the iac block off plates? The have smaller holes I believe and may help work with your idle issues. I have a breather on mine so maybe you could try that?
i just got one a few days ago actually, thanks to R.J., but i haven't installed it yet.
you have a breather on what? the valve cover vent?
what is your idle set to?
95cobraguy
637
11
Feb 3, 2006
#10
  • Feb 3, 2006
  • #10
i was playing with my oil separator yesterday, basically just mounting it to the firewall with a stupid L bracket i made and i took the filter element out and noticed in just the short time i drove it afterwards that more oil had collected than previously. i would get an oil separtor to start, it should clear up any oil being drawn into the intake.
KBCobra95
356
North Carolina
Feb 3, 2006
#11
  • Feb 3, 2006
  • #11
I have a breather on my valve cover vent, as well as a oil seperator. Idle is around 850-900.
BlackVert
5,589
9
98
Bethesda, MD
Feb 8, 2006
#12
  • Feb 8, 2006
  • #12
looks like the high idle was from my cruise control cable not letting the throttle close completely.
KBCobra95
356
North Carolina
Feb 9, 2006
#13
  • Feb 9, 2006
  • #13
So the cruise cable is too short?? I thought it was supposed to work? Did you switch to a fox TB?
BlackVert
5,589
9
98
Bethesda, MD
Feb 9, 2006
#14
  • Feb 9, 2006
  • #14
i'm thinking that the distance from the place where the bracket holds the cable to the throttle actuator was not exactly the same from my old setup to the new setup.
the elbow and the throttle body both changed when i installed the blower, so it doesn't surprise me that the distance wouldn't be exactly the same. i just didn't think to check it and i didn't notice that there was no slack there.
i bent the bracket towards the actuator a little which put some slack into the cable and now it's happy.
95cobraguy
637
11
Feb 9, 2006
#15
  • Feb 9, 2006
  • #15
if u dont use the cruise control u could always remove the cable.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
J
PCV system help for S/C
  • jay99914
  • Feb 16, 2025
SN95 4.6L Mustang Tech Sep 26, 2026
AngryH58
A
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
SURGING IDLE / NO IDLE CHECKLIST FOR 1996–1998 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
