  • 1994 - 1995 Specific Tech
PCV Hoses
  • Thread starter Thread starter LethalInjection
  • Start date Start date May 28, 2011
LethalInjection
217
Arkansas
May 28, 2011
  • May 28, 2011
Does anyone know the purpose of the pcv having 2 connections on the upper intake to draw vacuum? I have the bottom one on the plenum capped off and am pulling vacuum through pcv via the one on the rear. Are there any benefits to the 2 hoses tee'd together factory approach?
toyman
1,944
54
79
Vernon BC
May 28, 2011
  • May 28, 2011
According to the Ford vacuum diagram there is a single line from the intake to the PCV. I can see no reason to have two lines from the same source.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
May 28, 2011
  • May 28, 2011
This came up on Corral not long ago. The original design has two connections to provide more vacuum at different rpms by sourcing it from two points on the intake.
Kurt
toyman
1,944
54
79
Vernon BC
May 29, 2011
  • May 29, 2011
Kurt
I don't think that's physically possible. That's saying there is a vacuum differential within the intake. And even if it were true the differential between the two would be equalized by virtue of the common connection at the tee to the PCV.
toyman
1,944
54
79
Vernon BC
May 29, 2011
  • May 29, 2011
Kurt
I don't think that's physically possible. That's saying there is a vacuum differential within the intake. And even if it were possible the differential between the two would be equalized by virtue of the common connection at the tee to the PCV.
Stang D
122
Quad Cities, Iowa
May 29, 2011
  • May 29, 2011
It could conceivably spread out the oil flow to more cylinders in a high mile and tired engine. Highly doubt thats the design reason though.
revhead347
20+ Year Stangneter
Jun 14, 2004
9,302
1,645
214
Acworth, GA
May 29, 2011
  • May 29, 2011
That's a simplified explanation based on what I read. I don't truly understand it, mainly because it's not worth the time to understand it. You can look up the thread on Corral if you want to if you want the original answer.
Kurt
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
G
Vacuum hose?
  • Gandalf79
  • Mar 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 18, 2025
mayapril
M
Engine on3 Conversion to draw through MAF?
  • sav22rem22
  • Oct 11, 2025
Fox 5.0 Mustang Tech Oct 11, 2025
sav22rem22
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
