  • 1994 - 1995 Specific Tech
PCV poped out
  • Thread starter Thread starter urban96
  • Start date Start date Apr 3, 2006
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 3, 2006
  • Apr 3, 2006
anyone had their PCV valve pop out of the lower groument? what kind of drivibility issues did u have when it was out?
95CobraMike
1,046
Lima OH
Apr 4, 2006
  • Apr 4, 2006
mine used to pop out... it would cause stalling and stuff, rough idle... its pretty much a vac. leak
i think that it means you might have some blow-by.... a valve cover breather really helps so it wont pop out
94opalgt
358
AKRON,OHIO
Apr 4, 2006
  • Apr 4, 2006
your sig gives me a headache urban96.i think someone on here said if you run a breather that it could cause a lean condition cuz you are allowing unmetered air in that the computer does not know is there.i had a problem with it poping out,i went to the local dealership and bought new pcv and grommet and my problem went away.do not buy them for autozone,advanced or another place.i tried that and they didnt work the only one that did was one from ford
95CobraMike
1,046
Lima OH
Apr 4, 2006
  • Apr 4, 2006
i dont know about the comment made about running a breather causing a lean condition..... i could POSSIBLY see a rich condition IF any change at all in the A/F ratio caused by piston ring blow-by and running a breather...
any air sucked into the motor through the breather would most likey stay in the crankcase.... cause with a breather it wouldn't be under any pressure hence not being forced up into the combustion chambers.... HOWEVER when the air and fuel ignite in your combustion chamber it has nowhere to go but down and because it IS under pressure, it could be forced out around your piston rings....
i dont think it is possible for unmetered air to come up into the cylinder especially if the crankcase isnt under pressure
urban96
3,464
Syracuse, NY
Apr 4, 2006
  • Apr 4, 2006
i dont think it was pushed out by blowby, maybe tho
it is one of the cheap autozone ones i think it came out because of the air/oil seperator i have on it and the line was pulled kinda tight so maybe the combination of cheap part and pulled hose caused it to come out
i changed hose routing now tho so its not pulling, maybe ill pick up a new ford PCV
HISSIN50
34
129
Apr 4, 2006
  • Apr 4, 2006
Good call with the Ford PCV (it fits tighter than some aftermarket stuff). Ditto for the grommet and screen (the screen is clean, right?).
Forced induction guys sometimes end up Siliconing the PCV valve in (not something I would run out and do). Make sure the element in the separator didnt clog up (mine was pretty hard to blow through after not too many miles with dino oil).
Where guys start running into breather issues is when they have a stock (lean) tune, and run PCV and a breather (one or the other works, but a mix isnt great).
But if your grommet is older, me thinks a fresh one could fix the issue alone. They vulcanize badly.
Good luck Urban, and thanks for getting rid of the psychodelic thing in your sig. It was giving folks flashbacks.
urban96
3,464
Syracuse, NY
Apr 4, 2006
  • Apr 4, 2006
haha thanks, i couldnt stand the sig any longer myself.
i also cut out the filter in the seperator just incase the synth killed it
Guero
2,148
Apr 4, 2006
  • Apr 4, 2006
could any of this cause a bad idle? sorry to hijack
HISSIN50
34
129
Apr 5, 2006
  • Apr 5, 2006
Yep. The vac leak alone can play with the stoichiometry, as well as cause the idle to either be high or low (generally high, but not always).
Good luck.
Guero
2,148
Apr 5, 2006
#10
  • Apr 5, 2006
  • #10
ok thanks guess i should get a new pcv from ford.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
M
Idle control valve
  • miser143
  • Oct 31, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 1, 2026
General karthief
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
speedmaster new 302 block?
  • rednotch
  • Aug 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 16, 2026
rednotch
