PCV problem.
tcstang
Do they make higher flow pcv's? I have a factory one on a 67 mustang 408 stroker engine. I had to idle it up to keep it runnin then when i pulled the line off the pcv i had to idle it back down and it ran fine. I checked the pcv and its not stopped up neither is the line. What do you guys think? Thanks
Yes there are different flow rates. I think the larger displacement = larger flow rate. I have been told by old timers that getting a 426/460 pcv for a cammed up small block will help it idle.
In my opinion an open breather would work best in this situation. Plug the PCV hose on the carb and place the filter right on top of your valve cover. You can find them at your local auto store.
Not the best choice for a street engine. The air flow of the PCV helps to keep the engine clean inside. A PCV valve is just a controlled vacuum leak, it sounds like his is not "leaking" enough. Try a valve from a larger displacement engine before you eliminate the valve.
I got a different pcv sunday and put it on it helped. It still pulls the motor down some but i guess any restrictions are gonna do that. What is a good idle speed after the engine warms up i have mine idle at 900 right now do ya think thats to high an idle?
408 eagle fordged steel crank,H-Beam rods,JE inverted dome pistons,10.1 comp,performer rpm intake-cam-heads 2.02-1.60, edelbrock 750 carb,msd 6al+distributor,performance automatics comp c-4,3000 stall tci,9" rear.
Here is a pic of the motor.
It is the controlled vacuum leak that helps it idle. If you get rid of the PCV system, you will have to find a way to make the carb idle without it, which sounds like your problem.
Don't understand the comment about ditching the PCV on a stroker. I run a factory system of my 393 and it works great.
