pcv trouble
  • Thread starter Thread starter MattTheBat83
  • Start date Start date Oct 20, 2007
M
MattTheBat83
203
  • Oct 20, 2007
pcv valve keeps on popping out.... what should i do?
HISSIN50
34
129
Oct 20, 2007
  • Oct 20, 2007
If you are not forced induction (if you are, further measures are needed):
Have you replaced the grommet? Motorcraft PCV valves fit Ford grommets very nicely! Aftermarket PCV's often fit even a new grommet loose.
If you haven't, I'd replace the PCV valve, grommet and screen (aka breather) with new Motorcraft stuff. Then forget about it for a couple years.
Good luck.
vristang
4,933
101
124
Seattle
Oct 21, 2007
  • Oct 21, 2007
^like JT said
Make sure you have good fitting parts in there... The Ford stuff is supposed to fit pretty tight.
Make sure the pcv isn't 'plugged'
If the pcv pops back out after you put a new one in, then a compression and leak down test would be appropriate.
jason
D
Djstorm100
109
  • Oct 21, 2007
what if you have forced induction?
HISSIN50
34
129
Oct 21, 2007
  • Oct 21, 2007
Then you can have ring-seal and other issues which can require a different PCV valve or other bandaids to get the crankcase ventillation system up to par.
vristang
4,933
101
124
Seattle
Oct 21, 2007
  • Oct 21, 2007
^^^and make sure you aren't pushing boost pressure directly into the crankcase via the pcv or TB to VC hose...
D
Djstorm100
109
  • Oct 22, 2007
got any pictures of diagrams to help me out here?
vristang
4,933
101
124
Seattle
Oct 22, 2007
  • Oct 22, 2007
If I get bored tomorrow afternoon, I may sketch something out...
However, there are ALOT of ways to properly ventilate a crankcase...
Maybe you could provide some details on what you currently have, and others can suggest ways to adjust...???
jason
Fuel 1990 installing edelBrock intake
  • Beaker
  • Oct 5, 2026
Fox 5.0 Mustang Tech Oct 6, 2026
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
A
Catch can questions.
  • AngryH58
  • Sep 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2026
squeak93
Engine Looking for this part
  • limp
  • Nov 27, 2025
Fox 5.0 Mustang Tech Nov 27, 2025
limp
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
