pcv trouble
If you are not forced induction (if you are, further measures are needed):
Have you replaced the grommet? Motorcraft PCV valves fit Ford grommets very nicely! Aftermarket PCV's often fit even a new grommet loose.
If you haven't, I'd replace the PCV valve, grommet and screen (aka breather) with new Motorcraft stuff. Then forget about it for a couple years.
Good luck.
^like JT said
Make sure you have good fitting parts in there... The Ford stuff is supposed to fit pretty tight.
Make sure the pcv isn't 'plugged'
If the pcv pops back out after you put a new one in, then a compression and leak down test would be appropriate.
jason
If I get bored tomorrow afternoon, I may sketch something out...
However, there are ALOT of ways to properly ventilate a crankcase...
Maybe you could provide some details on what you currently have, and others can suggest ways to adjust...???
jason
