PCV valve location
  • Thread starter Thread starter Killa
  • Start date Start date Apr 16, 2012
Killa
1,006
56
49
Apr 16, 2012
  • Apr 16, 2012
Any one have picture of where is pcv valve location on 95 gt 5.0, I clean the TB and found alot oil on intake. some peoples say buying from ford dealer, but the kit from advance auto part is ok ? any tips on replace it ? thanks
Killa
1,006
56
49
Apr 16, 2012
  • Apr 16, 2012
found it . back to question, the kit from advance auto part, that come with pcv, the rubber and the filter, like under 10 dollar for all, or dealer for 35 dollar ?
HISSIN50
34
129
Apr 17, 2012
  • Apr 17, 2012
If you have the cheddar, get Motorcraft if you can (I would at least use a Motorcraft PCV valve and grommet). Some aftermarket valves don't fit the grommets very tight.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 18, 2012
  • Apr 18, 2012
Were your ears burning HISSIN? Someone was just talking about you.
Kurt
Killa
1,006
56
49
Apr 18, 2012
  • Apr 18, 2012
I order a kit from ford 35 dollar, will be here on friday. How do you take the filter off ? take off the grommet out first then filter ? or filter first then grommet ? thanks
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 18, 2012
  • Apr 18, 2012
The filter is under the grommet. You pull the gromment, then use a magnet to pop the filter out.
Kurt
Killa
1,006
56
49
Apr 18, 2012
  • Apr 18, 2012
thanks for the tips !
2vNotch
519
21
29
Rogers, AR
Apr 18, 2012
  • Apr 18, 2012
WOW....
HISSIN50
34
129
Apr 18, 2012
  • Apr 18, 2012
Kurt
That can't be good.
I figured I'd check back in and see how everyone was doing.
KGT, since it sounds like you haven't had the pleasure of pulling the breather/filter before, a telescoping magnet, long needle-nose pliers, a curved dental pick or a drywall screw are amongst the popular methods for pulling it out (ha ha, insert joke here. We're talking about the breather - that other stuff sounds painful)
revhead347
20+ Year Stangneter
Jun 14, 2004
9,303
1,649
214
Acworth, GA
Apr 18, 2012
#10
  • Apr 18, 2012
  • #10
Someone just mentioned that you hadn't posted since Christmas. Thay's all.
Kurt
Killa
1,006
56
49
Apr 19, 2012
#11
  • Apr 19, 2012
  • #11
update : part came today, pcv and filter is motorcraft and grommet is dorman wtf, i got rip off , anyway the old filter take off the needle nose is all clog up pretty bad, the pcv is new sound like new, but replace all,
the pcv hose is hard and crack at the end, i tape it with some black tape and it all good, imma plan to replace soon.
HISSIN50
34
129
Apr 19, 2012
#12
  • Apr 19, 2012
  • #12
You ordered a kit from Ford and they sent you a grommet in a Dorman package? The grommet is the most important part IMHO. The last one I got from the dealer was Motorcraft and the last one from LRS was also Motorcraft. That's weird.
Good call on replacing that hose. You might want to replace the other leg of it (at the T).
Killa
1,006
56
49
Apr 19, 2012
#13
  • Apr 19, 2012
  • #13
yes, the motocraft I took off was hard type rubber, and the dorman they send me is really soft, but fix perfectly, I guest no problem.
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
D
Please help with vacuum lines
  • Dawgs000082
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2026
Dawgs000082
D
G
Vacuum hose?
  • Gandalf79
  • Mar 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 18, 2025
mayapril
M
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
