  • 1994 - 1995 Specific Tech
PCV valve problem
  • Thread starter Thread starter 1SLO306
  • Start date Start date Oct 15, 2009
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Oct 15, 2009
  • Oct 15, 2009
ok Im getting a 95 GT from a buddy of mine and it blows the pcv valve out during WOT but doesn't do it and while driving normal. He says it also has a miss to it. He is suppose to bring it down to day and im going to check a few things.
Anyone fill me in on what could cause this. Ive heard and read that it could be cause my blow by.
revhead347
Apparently my ex-husband made that mistake.
20+ Year Stangneter
Jun 14, 2004
9,303
1,648
214
Acworth, GA
Oct 15, 2009
  • Oct 15, 2009
Blow by could cause it to blow out if the breather or the PCV valve is clogged. Probably take care of itself if you change the PCV valve.
Kurt
HISSIN50
34
129
Oct 15, 2009
  • Oct 15, 2009
The grommet is probably worn out and loose as well. Be sure to use Motorcraft for the PCV valve and grommet. Aftermarket stuff doesn't fit as tightly together.
G
greengoblin95
92
  • Oct 15, 2009
Kurt
too much pressure thats not escaping as stated above. make sure if the hose that comes off of the oil fill tube isnt clogged as well. thats the vent hose
GTA_V6_Mustang
1,326
Miami, FL
Oct 16, 2009
  • Oct 16, 2009
If its not blowing out the dipstick too I would just replace the crankcase filter and the valve and grommet, since its probably not blowby if the dipstick isnt coming out too (probably). And like hissin said the best to use would be the oe stuff. Or you can do what I have done to every mustang with this problem and aftermarket grommet/valve. I just wrap the grommet outside that seats against the intake with a good amount of teflon tape. Seals perfect and never lets it budge and even allows the valve to sit in tighter too, but will still come out easy if you need it to.
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
Intake vacuum lines
  • cnorman31
  • Mar 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 15, 2025
Scrapla347
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jan 11, 2026
02_2v_Curtis
