- Mar 30, 2005
- 4,749
- 95
- 134
How is that tech ma'am?lol..im seeing a pattern with this guy/girl
Do you own research, its not the thread topic. If someone is going to suggest blocking PCV or using breathers I am going to suggest othewise. If you want schooled further I suggest Google or a new thread.Thanks again for the knowledge you have added to this thread.![]()
I don't mind if you dissagree but atleast back it up with something useful.
I've never heard of removing the valve cover to remove the PCV valve. They unscrew, or pull straight out.
I would clean your IAC out and see if that helps, although since you said wandering idle, and not stalling, I would look for a cut vac hose, or a TPS problem.
That is not tech.Edit: Nevermind, I'm not going to argue with you, since it just a waste of bandwidth. Which is exactly what aggrevates me about most of your tech posts.
I have the pull out type, but I have also change them on some cars that you turned it 90 degrees to unlock it then pull it out.
Mine is also the pull out type... I can't see any reason to remove the valve cover in order to replace the PCV
The only thing I can think of is that the metal clip he was talking about was actually the locking mechanism that I was describing. I could see how it would be confusing if you didn't know you only you had to turn it to unlock it.
I think Ill stick with the stock system. It just started this idle problem. So Ill clean out the IAC first since thats free. Then move on from there. Thanks for all the input guys, I actually learned a few things from this thread.
when im hitting the gas full throttle i hear kinda like misfire after 4,000 rpm's and it feels so slow, i did the cap and rotor,my iac valve was replace for a high idle,fuel filter somebody told me it could be the ignition module or ignition coil i bought the car a month ago and this problem is killing me and the maf sensor was replaced that wasd throwing a code,,,, the car is not throwing any codes right now but it is choking at highway speed after 4,000 rpm.s why is this
