  • SN95 4.6L Mustang Tech
Pcv Valve Question
  • Thread starter Thread starter LuisFlores99GT
  • Start date Start date Nov 14, 2009
L
LuisFlores99GT
29
  • Nov 14, 2009
Just bought a new pcv valve and the one i bought looks sorta like an F, idk if anyone has seen this but if a picture in needed i will provide one anyway it dont really look like the stock one thats on my car now..
How would i install it?
RedDaemon
3,470
9
108
Atlanta, GA
Nov 14, 2009
  • Nov 14, 2009
pics please
myponyrocks
I have more billet on the Stang than most women ha
Apr 18, 2004
1,219
Nov 14, 2009
  • Nov 14, 2009
There's one with the pre-heater element, if your car doesn't have that one in already you live in a fairly warm climate and don't need it. There's also the chance that you aren't looking at the PCV, is the one you're replacing hollow? If so (and I did the same thing) then check the other valve cover
L
LuisFlores99GT
29
  • Nov 14, 2009
Ha yea im pretty sure im lookin at it but anyway heres what it looks like except that little part sticking out is in between those other two
AutoZone.com | Vehicle Selection | Year
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Nov 14, 2009
  • Nov 14, 2009
Model year?
Might be handy to know the car's year. The PCV system was redesigned in 2001. The PCV valve itself has a larger tube and a different attachment to the valve cover.
DJ Fury
72
Nov 14, 2009
  • Nov 14, 2009
Yeah autozone sucks balls. They carry the pcv valve for a 5.0 liter and list is as the part for 99-04 as well. The pcv valve you have has two plastic ports on it and the one we use only has one. Take it back for a refund, they don't carry the one we need. Go to your local stealership and get one.
myponyrocks
Apr 18, 2004
1,219
Nov 15, 2009
  • Nov 15, 2009
I would suggest teamfordparts or rockauto dot coms for small OEM type purchases in the future. Their online catalogue is pretty good at selecting the appropriate parts and usually show the comparable Motorcraft part number next to the knockoff if they don't have the OEM in stock.
L
LuisFlores99GT
29
  • Nov 15, 2009
The year is a 99,
But thanks guys i will do that
1987stangman
684
24
  • Nov 15, 2009
Most generic auto part store PCV valves come with two ports, it also comes with a plug to plug off the unused port. The only way to get OEM is go to the dealer. I just bought one for my 96' from Advanced Auto Parts. If I'm not mistaken, it will also fit the 5.0L too.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2009
#10
  • Nov 16, 2009
  • #10
Get a copy of the FRPP catalog while you are at the parts counter OP.
AdRock
521
South Texas
Nov 16, 2009
#11
  • Nov 16, 2009
  • #11
Just stop by a dealer and get the correct OEM valve. It's cheap. I think I paid $7 for the valve on my '02.
patman0911
2,287
Tuscaloosa, AL
Nov 16, 2009
#12
  • Nov 16, 2009
  • #12
It's not that big a deal. Just plug off the unused port - there should've been a plug in the package just for that purpose. If it bugs you that it doesn't look original then go to the dealer and grab one. The Autozone one will work fine though.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 16, 2009
#13
  • Nov 16, 2009
  • #13
Yeah I do not think the AutoZone one will be as good. But I agree there should be a plug you could just plug it. But expect to replace it sooner.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Nov 16, 2009
#14
  • Nov 16, 2009
  • #14
i honestly had more trouble withe the ford one, the autozone one would use less oil then the oem ford one.....
A
AKA3Toes
39
The land AKA Alabama. Always humid, whether hot or
Dec 11, 2009
#15
  • Dec 11, 2009
  • #15
A Little More Info for Future Readers & Those Watching This Thread
---The new style PCV valve works for a broad range of vehicles, including the 2.9L i6 IIRC. The P/N is assigned by the amount of vacuum needed to move the pintle and not simply the OD of the barbed fitting, grommet end, threaded end, etc., per application. Since the grommet end is the same size on most, and vacuum required for operation is the same, rather than make 4 or 5 different packages, train people to work the line differently, change laser jet for printing cases of parts, etc., one PCV Valve is made & it's up to you to make it match your old one.
---In between the 3/8" and 5/16" nipples there is a plug. Twist the plug off and insert it in the 5/16" nipple if the 5/16" nipple is unneeded.
---The plastic Tee and steel PCV Valve are separate. You can pull the Tee off the PCV Valve for use on the 5.0. BTDT.
---PCV Valves very rarely go bad and unless the valve's casing itself is plastic (like most cheap-o frams), there would be no need to replace it regularly. Cap off one end with a thumb, spray carb cleaner or similar solvent inside it, filling it half way, cover the other end with finger and shake "watch yourself" (eye protection). Some PCV Valves carry the same P/N they did 30 years ago and some 30 year old PCV Valves are still in use.
---The wire mesh filled "looks like a PCV Valve", if the 4.6 has such an animal, is as much not a PCV Valve as it was on my IHs from the 70s. PCV Valve's main job is to stop vacuum to prevent ignition of crank case gasses when under load and backfire occurs. That would be a breather element, and if a hose is hooked to it, running to/around the cold air intake, that would be a flame arrestor (see marine parts) of sorts. It is, simply put, the other end of the Crankcase Pressure System. The wire mesh can be cleaned with the same solvents as the PCV Valve, in the same way.
  • Gulftown980x
  • Jul 29, 2026
squeak93
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 16, 2026
AeroCoupe
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
SN95 V6 Mustang Tech May 23, 2026
DPP
D
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 24, 2026
squeak93
