PCV vs Breathers
  • Thread starter Thread starter 67GTA-FB429
  • Start date Start date Feb 5, 2004
67GTA-FB429
777
Tri-Cities, Wa
Feb 5, 2004
  • Feb 5, 2004
I am adding new valve covers to my engine as part of my suspension build up. Since smog-laws are a non-factor for me. What would be better:
1) One breather and one PCV-to-carb fitting
-or-
2) Two breathers
Let me know what you think.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 5, 2004
  • Feb 5, 2004
I'd go the environmentally friendly PCV route. A PCV does NOT degrade performance and if it does, you have far greater problems.
6Stang7
1,470
Livermore, CA
Feb 5, 2004
  • Feb 5, 2004
Another advantage of a PCV system is that the crankcase fumes are corrosive to your bearings and rings, so by removing them you will reduce wear on your engine.
-Shaun
G
gp001
4,401
So. Cal.
Feb 5, 2004
  • Feb 5, 2004
Go with choice #1. If the 2 breathers can not vent the pressures adequately you will wind up blowing seals/gaskets.
2nd Mustang
2,488
Southern California
Feb 5, 2004
  • Feb 5, 2004
The 2 breather route will also cause a big mess on the headers and valve covers, go with the PCV and one breather.
67GTA-FB429
777
Tri-Cities, Wa
Feb 5, 2004
  • Feb 5, 2004
I have been running two breathers on the old covers, no blown seals or leaks, nor were there any messes on top of the engine. Mainly wondering if there was a power advantage....I am leaning towards the PCV route since it is environmentally friendly and it will help gain some underhood clearance (monte carlo bar!!)
2nd Mustang
2,488
Southern California
Feb 6, 2004
  • Feb 6, 2004
I read that reducing crankcase pressure helps piston rings seal better on drag motors, like those breathers that hook up to a check valve connected to the collectors on the headers. The pulses of the exhaust helps to evacuate pressure out of the crankcase.
SuperDave
Early-Model Mentor
6,361
Tacoma, WA USA
Feb 6, 2004
  • Feb 6, 2004
Isn't crankcase pressure caused by "blow-by" past the rings/pistons? (I'm just asking) In that case, wouldn 't that indicate top-end problems that would need to be addressed?
G
GaPonyFarm
663
Columbus, GA
Feb 6, 2004
  • Feb 6, 2004
-or-
2) Two breathers
I'm still wondering what valve covers have to do with suspension???
Definitely go with option #1 and check to be sure you have baffle plates under the openings of the new valve covers, else you'll have oil everywhere! Just a friendly reminder......
67GTA-FB429
777
Tri-Cities, Wa
Feb 6, 2004
#10
  • Feb 6, 2004
  • #10
Valve covers have everything to do with my setup. Becuase of engine height, I have to have everything is place to figure out if my export brace and new Monte Carlo bar will fit. The export brace has checked out, but the Monte carlo bar will hit the breather. So, it is use a PCV valve on the left side or get a custom made monte carlo bar. Or don't use anything on the left side, Or design a custom breather setup.
Does anyone know if the PCV valve will work if it is on the left side of a 385 series engine??
6Stang7
1,470
Livermore, CA
Feb 6, 2004
#11
  • Feb 6, 2004
  • #11
Yes, but "blow-by" is only part of it. The other part is the fumes released fromt he oil when it gets hot.
-Shaun
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Tuesday at 7:51 AM
AlexM556
A
P
Vacuum
  • ProTechAutoServices
  • Aug 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
N
Edelbrock 1405 Setup
  • nathantaylor200
  • Nov 4, 2025
Classic Mustang Specific Tech Nov 5, 2025
nathantaylor200
N
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
