  • SN95 4.6L Mustang Tech
PCV!?!?!
  • Thread starter Thread starter TorqueMonster88
  • Start date Start date Apr 17, 2008
TorqueMonster88
46
  • Apr 17, 2008
How do u get this thing off.....its like its glued on or something...and then how do you get it back on??
2000fordstanggt
404
Westland, MI
Apr 17, 2008
  • Apr 17, 2008
theres a gromet on the valve cover that it sits in. pull it straight up, the new one goes straight down. might kinda be stuck but itll come out.
TorqueMonster88
46
  • Apr 17, 2008
what about for seafoam....sorry i didnt mention that before...is it the same thing do you feed it in from the grommet?
2000fordstanggt
404
Westland, MI
Apr 17, 2008
  • Apr 17, 2008
i always use the vacuum line from the t/b to the pcv for seafoam. a rubber hose will actually fit over the end and it works great, paired with a funnel, of course.
the reason i dont take the hose right off the t/b is cause mine is dryrotted.
TorqueMonster88
46
  • Apr 17, 2008
thats what im talking about that rubber piece that goes from the t/b to the plastic tubing to the pcv....separating that rubber from the plastic is hard....any remedies?
BurningRubber
1,865
24
58
Apr 17, 2008
  • Apr 17, 2008
Twist it to break the seal the rubber has on the plastic, it will come off easier.
Also, you arent trying to tug on the valve on the drivers side cover, correct? The PCV is on the passengers side, and it should pop right out and in. If not, rotate it a few degrees and try again.
TorqueMonster88
46
  • Apr 17, 2008
oh no...i guess i had a misunderstanding.....the pcv comes out easily(on the passenger side)....i had the idea that the whole hose assembly was the pcv..haha...but anyway, the advice helped i got it off....now i can finally seafoam now..hahaha
2000fordstanggt
404
Westland, MI
Apr 18, 2008
  • Apr 18, 2008
remember to change your plugs/oil soon after you seafoam
R
Efi to car pcv HELP !
  • rgrendell
  • Jul 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 2, 2026
  • Gulftown980x
  • Jul 29, 2026
squeak93
W
2.3 l pcv canister
  • waxman
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 16, 2025
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
O
1978 Mustang II Headliner Install
  • onusideburns
  • Nov 4, 2025
1974 - 1978 Mustang II Talk & Tech Mar 9, 2026
Enzio
