Pedestal mount rocker help
  • Thread starter Thread starter 9 Deuce GT
  • Start date Start date May 1, 2005
9
9 Deuce GT
550
Geneva, NY
May 1, 2005
  • May 1, 2005
I just finished installing a TFS Stage 1 cam in my '92 Mustang. When I tried to install the FMS roller rockers, I ended up using shims. The problem is, I need to get 2 shim kits to get the right preload. I thought I remember reading that you cam only go to .090 when using shims. So this got me thinking. I tore down the rocker system, and decided to measure the thickness of the shims. I was under the assumption that the 2 different sized shims were .030 and .060 thick. When I measured the shims, the thin ones are .020 and the thick ones are .035. So now I am a little confused. All but one of the intake rockers need one.020 shim, and two .035 shims. The exhaust rockers need one .020 shim and one .035 shim. The biggest amount of shims totals .090. I examined each valve tip for roller wear before I installed the shims, and I tried the marker method after I used the shims. The marks are a little bit toward the intake side, but the wear pattern is tight. slightly under the .080 range. Would this setup with shims be okay, or do I need different length pushrods?
rd
3,316
63
109
Ocean Springs MS
May 1, 2005
  • May 1, 2005
From memory, I thought the Crane Cams shim kit was like you described it. I bought it, installed some during a chase that turned out to be a vacuum leak, and then I removed them.
If the roller contact is near the center, I would not worry so much. If the piston to valve clearance is good, and there is no obvious mismatch or binding in the rockes, it should work, especially with the roller tips.
9
9 Deuce GT
550
Geneva, NY
May 2, 2005
  • May 2, 2005
A little help here!
RYC CUKR
1,437
Orlando
May 2, 2005
  • May 2, 2005
You can also get shim kits through www.summitracing.com. Not gonna really help if you need them right now but they do sell shim kits for pedestal mount heads. They have a ford kit with .30 and .60 shims and a crane kit. Here is the part # for the ford kit FMS-M-6529-A302 it costs like $8.88. Hope this helps
Resolved Fixing a GT40P Valvetrain nightmare
  • foxbodyclark
  • May 21, 2025
Fox 5.0 Mustang Tech May 24, 2025
limp
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Lifter preload on GT40 pedestal rockers
  • limp
  • Apr 5, 2023
2K
Fox 5.0 Mustang Tech Apr 17, 2023
limp
