  • 1994 - 1995 Specific Tech
Performance distributors?
  • Thread starter Thread starter milewsky80
  • Start date Start date Jun 25, 2007
milewsky80
69
Weirton, WV
Jun 25, 2007
  • Jun 25, 2007
I've seen a few people here running the livewires but does anyone have any experience with their "firepower" kit?
http://www.performancedistributors.com/5.0ignition.htm
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 25, 2007
  • Jun 25, 2007
I don't know a whole lot about the various after market ignition options
cause
For a NA combo, many have found the OEM stuff to be quite adequate
If you are looking for more than a very slight performance gain ......
Look in a category other than ignition ... no matter what the adds promise
Grady
95BLKGT5.0
608
Auburn Washington
Jun 25, 2007
  • Jun 25, 2007
I have the Livewire Fire Power kit and I love it.<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" alt="" style='width:18.75pt; height:13.5pt'> <v:imagedata src="file:///C:\DOCUME~1\Dan\LOCALS~1\Temp\msohtml1\01\clip_image001.gif" o:href="http://forums.stangnet.com/images/smilies/thumb.gif"/> </v:shape><![endif]--><!--[if !vml]--><!--[endif]-->
My plugs look perfect; better throttle response, more bottom end torque. And no pinging.
On a open track day before the kit I could get to 128 MPH at the end of the straightaway before having to let off for turn 1.
Last time I went was after installing the Fire Power Kit and I did 135 MPH on the same track.
I guess what I’m saying is it was money well spent.
Venom351R
4,548
41
98
MAINE
Jun 25, 2007
  • Jun 25, 2007
Ive seen that kit advertised before it seems to be a pretty good kit. Ive got an MSD 6AL box, MSD coil and Taylor wires and that seems to work pretty good for me.
milewsky80
69
Weirton, WV
Jun 26, 2007
  • Jun 26, 2007
cause
Grady
Not looking for too much gain. My cap and rotor are almost 3 yrs old , the coil is stock (150K miles) and I'm pretty sure the wires are still stock so I figured I'd upgrade it all at once. No one had anything bad to say about it so I might go for it. I'll update friday when I decide.
RIO5.0
6,892
N.H.
Jun 26, 2007
  • Jun 26, 2007
I run the PD kit to..No complaints. I used an MSD dizzy...I think they just came out with that dizzy as its a Ford unit just beefed up bearing wise and such...Few years back they didn't have it or I would have got one....They had another type for like 100.00 over a 300.00 MSD....
J
JNeidlinger
31
  • Jun 26, 2007
I've always stuck with MSD for coils/rotors/caps, and Taylor for wires. Always been able to squeeze a little more gap out my plugs that way and be completely reliable. With the MSD Blaster Coil, MSD Cap and rotor, and Taylor wires, I run the plugs just around 0.060 just like that PD set says you can, and its considerably cheaper.
bimmertech
1,123
merriam, ks
Jun 26, 2007
  • Jun 26, 2007
i just replaced my msd billet distr after 1 year biggest waste of $$$ i ever spent on my moneypit, got it after my stocker went bad.
i did the whole deal, computer distributor, livewires, coil, dyna mod. i can't say how well it works yet, because i have another issue keeping me down right now.
Pokageek
2,767
MA, USA
Jun 27, 2007
  • Jun 27, 2007
I have heard the same thing from others Bimmertech. That's why I went livewires too for my 408. I have had it on the 306 and had no issues. It pulled better throughout the RPM band.
WhiteDevil
2,717
San Diego
Jun 27, 2007
#10
  • Jun 27, 2007
  • #10
I have it. Didnt do anything for me that my stock **** didnt.
9
94v6GT
141
#11
  • Jun 27, 2007
  • #11
so is the consensus that stock replacement ignition components are sufficient for say 350whp and under?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 27, 2007
#12
  • Jun 27, 2007
  • #12
Its not so much about the amount of power
It is about the application
Lets keep it simple and look at two different applications
Power Adder Folk have spark blow out issues to deal with that typical
NA h/c/i combos don't
Grady
Pokageek
2,767
MA, USA
Jun 27, 2007
#13
  • Jun 27, 2007
  • #13
I have been told that you don't need it N/A until you hit 400rwhp.
Therian
The Highlander
Waterloo, Ontario
Jun 27, 2007
#14
  • Jun 27, 2007
  • #14
I don't like thresholds like that...seems too black and white. I'm with Grady on this one
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Jun 27, 2007
#15
  • Jun 27, 2007
  • #15
As with most upgrades .....
Some are more worth while than others
Performance ignitions on NA combos don't usually give much gain
simply because ... the stocker is not all that inefficient
Lets use the hp values of 350 and 400 and see how they compare to .......
A typical h/c/i combo you see on our site all the time
Many 275-325 rwhp combos have used the OEM ignition with success
If we move up to a Windsor and build a similar 1 rwhp to 1 ci combo ...
That would put us in that 350 to 400 rwhp range
I don't see how the OEM stuff is gonna be working any differently
in an application such as that
I say ... don't spend money where it does little good
I say ... do spend the money on better quality parts where it can
make a real difference ... like heads, or cam, or meter, or LT's, etc
Grady
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
R
Microsquirt tune for stroked 351W in a foxbody
  • roldy
  • Jul 26, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 11, 2026
roldy
R
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Fox 351 dipstick showing overfull?
  • 387lx
  • Feb 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 9, 2026
