Pertronix and wiring
  • Thread starter Thread starter Max Power
  • Start date Start date Oct 4, 2004
Max Power
1,774
St Paul
Oct 4, 2004
  • Oct 4, 2004
Just got flatbed towed for the first time in twenty years, and it appears I have ignition issues.
I have a new 393, and on it I put a new Pertronix coil. I had already installed the Pertonix 1 module about 6 years ago. It flat cut out on me yesterday.
The coil is fine, I tested with a known good coil, so I have narrowed it down to the ignition wire or the old Pertronix module. Before I condemn the module, I need to know a couple of things.
This is a 69 model, btw.
What is the voltage supposed to be to the coil from the ignition switch while running through the resister wire?
Are people running this set-up without the resistor wire using straight 12v?
And finally, where physically is the resistor wire? The schematic suggests the resister wire is not in the loom under the hood that goes directly to the guages and coil, but it is not clear if the resistor wire is under the hood or under the dash. I don't have my factory shop manual with me at the office, so any input would be appreciated.
Any other ignition comments welcome....
O
Ozsum2
695
  • Oct 4, 2004
I could tell you, but given the recent attacks that you have enjoyed on me, I'll let you figure this one out for yourself.
Max Power
1,774
St Paul
Oct 4, 2004
  • Oct 4, 2004
You must be a very bored individual. Why not get a life?
Grow up.
O
Ozsum2
695
  • Oct 4, 2004
Max, I'd like to know why you must continue this badgering of me? Why can't we just agree to disagree on some subjects and let it drop? You seem to enjoy posting these little jabs and quite frankly, I am getting tired of it and will be voicing my concern to the moderator if you continue. Consider this your final warning.
whwright
150
Oklahoma City
Oct 4, 2004
  • Oct 4, 2004
Hey Max.
On my 72 model, the resistor wire is connected to the factory tach in the dash. I bypassed it when I put in an Accel distributor.
If I understand correctly, the engineering from 69 to 73 didn't change very much, so I would speculate that the resistor wire on your car originates under the dashboard too, whether you have a factory tach or not.
From what I've gathered over the years, running most electronic systems other than Accel -- including Pertronix (sp?) -- without a ballast resistor of some type will overheat and eventually destroy the electronics.
How many miles did you put on the unit in six years? Maybe it was just time for it to go to electronics heaven.
Good luck.
Wayne.
btw: IMHO, if somebody doesn't have something contributory to post, then don't post at all (or as I tell my kids, "if you don't have something nice to say, then just don't say anything"). My .02 worth.
66HertzClone
428
Central New Jersey
Oct 4, 2004
  • Oct 4, 2004
I can tell you how my 66 is setup, I don't think yours will be much if any different. The resistance wire connects directly to my ignition switch, it is covered with a woven fabric like guard, same stuff on the pressure switch lead. The wire is a resistance wire its entire length, from the male plug to the bulkhead connector at the firewall. I can't tell you the voltage thru the wire, frankly I never checked, car started, no problem. I ran Petronix for about a year and left the resistor in place, despite the instructions that say to bypass it.
I have since replace the engine and am using a MSD ready to run dizzy. I bypassed the wire for this unit. I cut the wire off as close to the bulkhead connector as possible, soldered a new wire in its place which I connected to the ignition switch. I left the old wire in place should I ever decide to go back to a stock engine.
If you have voltage at the positive (ignition switch side) of the coil when the key is on, the wire is good. The circuit is either closed or open, however you may want to check its length for cuts or nicks that may allow the circuit to ground out.
BTW, I kept the old set of points and condenser, screws, and a feeler gaug in my glove compartment, you never know......
Max Power
1,774
St Paul
Oct 4, 2004
  • Oct 4, 2004
Thanks whwright. Probably 50,000 over those six years. The Pertronix instructions say to run 12v, but that it will work with less, to a point. Right now I have next to nothing at the coil, so I think I will be searching for opens in the wiring. I was kinda hoping to avoid going under the dash this late in the year. It's getting close to storage time.
Max Power
1,774
St Paul
Oct 4, 2004
  • Oct 4, 2004
OK, normally I wouldn't address this as it is painfully dull to others on the board, but I think that if any fair minded moderator would go back and look at our exchanges, they would have a hard time coming up with the same conclusions that you have. You can go cry to your moderator if you want, I am confident by the reactions of others here to some of your posts that I probably don't have much to worry about.
It's not your position to give me warnings about anything.
IMO, you could lose the attitude and grow a thicker skin. I don't care how long you have been here. That's all I am going to say on the matter.
Max Power
1,774
St Paul
Oct 4, 2004
  • Oct 4, 2004
Thanks Hertz! I was hoping by 69 they would move the resistor under the hood, but I guess not.
And to think I used to hate Chrysler ballast resistors. At least you could get to 'em!
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
Fox Ideas for Theft Deterrence in Storage
  • Clutchfork
  • Nov 6, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2025
91AOD5.0LX
G
Resolved Please help! (starting issue)
  • Ghoste
  • May 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2025
Ghoste
G
