M mustangfo New Member Apr 11, 2005 26 0 1 Jacksonville Apr 26, 2005 #1 Apr 26, 2005 #1 I have a 97 GT with only a PI head swap . Would I be ok to run to run a Zet Wet kit with everything being stock. I will probly run the 100 shot.
R Rekokulous New Member Mar 30, 2005 37 0 0 Apr 27, 2005 #2 Apr 27, 2005 #2 Yes, That is the prefered way to go after a PI swap because of the increased compression. Nitrous works well with high compression. Just make sure to buy all the goodies with your nitrous kit to be safe.
M mustangfo New Member Apr 11, 2005 26 0 1 Jacksonville Apr 27, 2005 #3 Apr 27, 2005 #3 So i dont have to advance the timing any?
S sgramer Founding Member Feb 6, 2002 97 0 16 San Rafael, Ca Apr 27, 2005 #4 Apr 27, 2005 #4 mustangfo said: So i dont have to advance the timing any? Click to expand... If anything you would want to retard the timing some, and go to a lower heat range plug. Scott
