  • SN95 4.6L Mustang Tech
pi heads conversion + which cams
  • Thread starter Thread starter chevyboy_z28
  • Start date Start date Mar 22, 2007
chevyboy_z28
66
Wixom, MI
Mar 22, 2007
  • Mar 22, 2007
ive got a 98 gt with stock internals and was wondering what options i have as far as cams if i convert to pi heads. I know there are several options for pi headed cars, but in converting to pi heads i raise the compression of my npi motor to 10:1. now with bigger cams in pi heads, on a npi shortblock will i have ptv clearance issues?
basically what im dealing with is this, stock npi shortblock+ patriot stgII heads (ie600 lift springs), + which cams? all the comp cams for pi heads have .550 lift, and the ones i was looking at getting (xe278ah), i was told that i would definately have ptv issues, with having a npi shortblock?
stangman
2,690
10
69
in a 3 bed, 2 bath
Mar 22, 2007
  • Mar 22, 2007
vt stage 1 cams pretty much anything larger & yu're going to have ot have valve reliefs cut in your pistons
CobraM23
266
Johnson City, TN
Mar 22, 2007
  • Mar 22, 2007
VT stage II NA cams here. No PTV problems either.
chevyboy_z28
66
Wixom, MI
Mar 22, 2007
  • Mar 22, 2007
what kinda gains are to be had with the stock npi heads and a decent set of cams? will the vt stg1s work with npi heads?
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Mar 22, 2007
  • Mar 22, 2007
I've got comp 262's and they are great. No PTV contact and they added around 20 rwhp on top of the gains from the pi swap. But, if you are going to do it, get cam gears with it and have them degreed in for even more gains. That's something I didn't do, and it kept me from hitting my goal of 275 rwhp.
Skidzz
Tinkerbell
Apr 11, 2005
328
Salt Lake City, UT
Mar 22, 2007
  • Mar 22, 2007
20-30 rwhp gains, depending on the grind. I don't think VT even makes a cam for NPI's, but comp does. My advice would be not to even change the heads. Get the PI intake and an adaptor, and then get some comp 268's for the NPI heads. You can even buy them from VT's web site for $565 right now, but you might find them cheaper somewhere else. That way, you will still put down probably over 250 rwhp and you will keep the compression low, so you get still run on regular gas and get a blower later on, not to mention you'll save a lot of $$$
chevyboy_z28
66
Wixom, MI
Mar 24, 2007
  • Mar 24, 2007
would it be worth it to go with the crower spring kit offered on the vt site, or are the comp srings (best seller list) good enough. ie the crower springs come with retainers, and are allegedly good up to .660 lift. i know thats prolly overkill for me right now, but there only $60 more than the comps?...i know the vt stg1 ones dont require a spring upgrade, but ide rather be safe than sorry (i dont cut corners to save a lil cash)
four six
506
Hobart, IN
Mar 24, 2007
  • Mar 24, 2007
VT stage 1 or 2
I love the sound of stg 2
chevyboy_z28
66
Wixom, MI
Mar 24, 2007
  • Mar 24, 2007
yea i like the sound of the stage2s also, and i think theyd work well with my current mods if i had ported pi's and a strong shortblock.
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
New Exhaust for 408w stroker
  • SadbutTrue
  • Sep 10, 2026
1965 - 1973 Classic Mustangs -General/Talk- Sep 10, 2026
nickyb
