  • SN95 4.6L Mustang Tech
pi headswap problem
  • Thread starter Thread starter silostang
  • Start date Start date Mar 14, 2004
silostang
24
San Antonio, TX
Mar 14, 2004
  • Mar 14, 2004
I bought some used p&p heads from friend. I put it all on, car starts and runs ok.
so heres my problem. car sounds like a freakin diesal truck. friend i bought the heads off of says that the lifters might not be pumped up. has anyone had this problem after doing the swap? anyone ? i need help quick car sounds like 'Kiss Me''Kiss Me''Kiss Me''Kiss Me'.
onlyme
375
missouri
Mar 15, 2004
  • Mar 15, 2004
hum
Usually when you hear that noise tis a detonation problem which means your timing is off or your having a fuel problem.I know caud my grandpa his truck did the same thing and so we checked the timing and it was off and when it was reset it was fine, no more deisel sound.
9
96stangn
15
  • Mar 15, 2004
The problem is that you probably didn't lube your cams enough during the install. If you didn't oil up the cams and valvetrain before reassembling your engine, that would be the definite cause of your car sounding like a diesal. I know you already completed the install, but these sites were very helpful for me when I did my swap. Good luck!!
http://www.enthusedproductions.com/headswap/
http://members.tccoa.com/embalmer/headswap.html
http://kmruk.home.mindspring.com/sohc_timing.htm
http://www.geocities.com/s2e3f4/headswap.htm
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
00 4.6L V8 new clutch won’t go into gear when on?
  • Timboslice
  • Aug 15, 2026
  • The Welcome Wagon
The Welcome Wagon Aug 21, 2026
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
