  • SN95 4.6L Mustang Tech
PI Intake Progress
  • Thread starter Thread starter spitfirees20
  • Start date Start date Jun 23, 2007
  • 3
  • 4
First Prev 4 of 4
spitfirees20
38
#61
  • Jul 6, 2007
  • #61
Finally got it working! My dad and I took off the plenum, and the bolt that I broke off had a little bit sticking out of the intake. Luckily, it was enough to grab with plyers and pull out, and it wasn't cross threaded at all, so we were able to just get another bolt and fix that. Also, the new gasket I had between the plenum and the intake manifold had a shred in it, (probably from me over tightening it ) so we fixed that also. We took off the fuel rail, cleaned all of the injectors and electrical connectors, and while we were at it replaced all of the spark plugs. Also, one vacuum line was old and ripping at the end, so for now we just cut the end off and put it back on, but I'm going to replace it. Runs like a champ now! Thanks for your help everybody.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Jul 6, 2007
#62
  • Jul 6, 2007
  • #62
Great news!!!
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Jul 6, 2007
#63
  • Jul 6, 2007
  • #63
See? And you were ready to pitch it in the volcano.
Glad you got it going. I know how frustrating it is trying to track down a mechanical problem. Just went through one myself.
M
Mel96GT
255
San Diego
Jul 6, 2007
#64
  • Jul 6, 2007
  • #64
I'm not surprised the gasket and vacuum line were what were causing headaches. These 4.6's are real finicky if they are not asssembled perfectly. You should learn to use a torque wrench and look up the torque numbers in the owner's manual. BTW, how do you like the new power curve? How about your torque? My low-end torque decreased slightly but my power band is much better above 3000 rpm.
spitfirees20
38
#65
  • Jul 6, 2007
  • #65
I'm not sure if the gasket and vacuum line were the only causes, but fixing them didn't hurt The new power curve is great, down low I really don't think I lost much torque, at least it doesn't seem like it, but when I get on it the power is awesome Pulls right to redline now, I gave it a quick run and it almost felt a little scary. However, aside from a tuner I'm done with these bolt-ons now. I'll save up for the SC
DTNODYA
831
#66
  • Jul 6, 2007
  • #66
This type of experience will make you appreciate when things go right!!!
Glad to hear that its running good.
LI98GTStang
1,715
L.I., NY
Jul 6, 2007
#67
  • Jul 6, 2007
  • #67
Glad you got it and that it was a minor fix. An important lesson I've learned working on cars over the years is to never overlook the simple answers...
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 7, 2007
#68
  • Jul 7, 2007
  • #68
it was not the gasket and vac line, that would not cause a misfire under load. it was probably the plugs or the connection to the plugs or dirt that got in the injectors.
most likely the plugs....
A intake leak would cause unmetered air to enter the intake this would cause a lean condition only near idle. once you get a load on it and vacuum drops then fuel trims would return to normal or near normal. The PCM adjusts for the lean condition and will add up to 25% to the fuel trims before it will trigger a p0171 and or a p0174 code. His vacuum leak was not that bad because he did not throw those codes and he did not have a surging idle.
If you have a scan tool with live data you can watch your long term fuel trims and if you see fuel trims near or at +25 at idle but then drop to near normal at higher RPM's or under load then you know it's a vacuum leak thats causing unmetered air to enter the intake.
M
mikeetown
11
Canada, BC, Kelowna
Oct 31, 2018
#69
  • Oct 31, 2018
  • #69
I’m basically having this problem but not throwing any codes at all. I have a 96 GT that I did the PI intake swap onto non-PI heads. For the first 24 hours of driving I had zero problems and then suddenly after my 15th WOT run I had a misfire under kid. inconsistent as well. Here is a video
View: https://youtu.be/4-Sugrlh0JI
But anyway, I’ll probably have to take apart my fuel rail and clean it. If there are any thred people remember on fuel rails and injectors please post for me or link it
I did put all
new seals on my injectors and removed every injector from the fuel rail.
Maybe that’s where I messed up
I’m glad there was a good ending to this thred
  • 3
  • 4
First Prev 4 of 4
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
I
Engine Insane fuel trims +25% LTFT Bank 1, -16% LTFT Bank 2
  • imw_stl
  • Aug 31, 2025
SN95 4.6L Mustang Tech Sep 19, 2025
Mustang5L5
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jul 19, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Saturday at 5:19 PM
manicmechanic007
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
