PI intake
  • Thread starter Thread starter FoxRod87
  • Start date Start date Dec 6, 2007
FoxRod87
243
Carolina
Dec 6, 2007
  • Dec 6, 2007
I have a 96 gt and I am woundering will a PI intake be a good upgrade. If so I think there are some adaptor plates that are needed. Where can I get some? and how much power should this give me? Thanks!
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Dec 6, 2007
  • Dec 6, 2007
no adapter plates needed, just gaskets.
FoxRod87
243
Carolina
Dec 6, 2007
  • Dec 6, 2007
So is it a good intake to swap to?
Jacob_Royer
142
  • Dec 6, 2007
Is it possible to run PI intake and PI cams on a NPI engine? if so will it do anything?
d98gt
4,505
59
204
SE Texas
Dec 6, 2007
  • Dec 6, 2007
Most popular swap available Jacob
You'll need to use a little RTV for the intake swap to work, which isn't too big of a deal. The pi cams pop right in and help out aswell
You'll pick up 30-35 horsepower by doing that swap and it can be done for CHEAP. There is a member on here that is selling NEW pi cams for $75 I believe, and you can pick the pi intakes with the alum crossover for $100 on most classifieds. I sold the PI intake with alum to HoustonGT from this board for $75 so just look around.
Good power for cheap---something you don't hear much with these 4.6s
CobraRed_96_GT
1,421
UCSD/La Jolla
Dec 6, 2007
  • Dec 6, 2007
It's popular, cheap, and effective
Jacob_Royer
142
  • Dec 7, 2007
How much trouble is it to change the cams and intake in one of these things??? Ive just not had an experiance working on the 4.6.. But i just rebuilt a supercoupe engine and if i can do that i can probably do anything! that was the biggest PITA of all things mechanical ever done in my lifetime and i've rebuilt probably a dozen engines even a toyota once.. It literaly took 2 days to unhook everything and pull the engine and thats with air tools indoors with good lighting.. Took another 3 hours just to strip it down to take to the machine shop..... More crap came out from under the hood than would fit in the back of a pickup truck hehe.. So really how bad is it to do the swap?? You are saying that PI cams and Intake WITHOUT the heads will pickup 30hp or so right?
CobraRed_96_GT
1,421
UCSD/La Jolla
Dec 7, 2007
  • Dec 7, 2007
yeah, 30hp is a good estimate to gain over what you have now. Really swapping the Pi intake isn't that hard, and some reading will point you in the direction of how to install PI cam ez.
Jacob_Royer
142
  • Dec 7, 2007
cool...Car seems to run out of ballz and do nothing but make noise over 5200rpm will pi cams and intake solve that?
CobraRed_96_GT
1,421
UCSD/La Jolla
Dec 7, 2007
#10
  • Dec 7, 2007
  • #10
wont "solve" it. But it will sure help, these cams and intake are for better flow and that peaks at high rpm's. Our stock peak hp is at 4400 while PI stangs are at 5250. Im going PI swap + VT cams so it will be more like 5400 I better learn to love revs
Jacob_Royer
142
#11
  • Dec 7, 2007
  • #11
Can the cams and intake be tackled in a day?
Winters98GT
1,291
224
H Town
Dec 7, 2007
#12
  • Dec 7, 2007
  • #12
intake, yes....... cams, proboly not unless you have experience tearing down a 4.6.
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Dec 7, 2007
#13
  • Dec 7, 2007
  • #13
I did my intake in a day. Cams can be done in a day but take your time. I did mine in two. Do a search in Tech on intake swap and cam swap. Lot's of good info here and on some other sites.
Jacob_Royer
142
#14
  • Dec 7, 2007
  • #14
Is it best to do both at once or does it really make one easier than the other to do at the same time? ie: having the intake off when you do the cams?
Jacob_Royer
142
#15
  • Dec 7, 2007
  • #15
Will any 99-up 4.6 intake work? or just mustangs?
d98gt
4,505
59
204
SE Texas
Dec 7, 2007
#16
  • Dec 7, 2007
  • #16
You can find some off of other 4.6s, but make sure they are PI and have the alum crossover.
Also--the pi intake will take ATLEAST a day since it's best to let the RTV cure for many hours before you crank up.
Jacob_Royer
142
#17
  • Dec 7, 2007
  • #17
No biggie there i can let it sit in the garage overnight...
T
TGJ
1,049
#18
  • Dec 7, 2007
  • #18
Actually,
You want the 01+ PI intake with the aluminum crossover. 99 - 00 and some 01's had plastic crossovers.
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
Vacuum line question?
  • Mustang Momma
  • Feb 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- Mar 3, 2026
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
