It's probably a dorman intake. It should work fine, just be sure it has the aluminum coolant crossover in front. Couple things to remember:
If you have a 96-98 mustang you need to tap the new crossover on the intake to accept the second coolant temp sensor installed on earlier NPI Mustangs.
You'll also need to use an alternator bracket from a 99+ Stang.
Other than that, I'll assume you bought PI intake gaskets so be sure to use some RTV in the coolant passages on the NPI heads that don't match up with the coolant passages on the PI intake.
Regarding the alternator bracket and 2nd coolant sensor. If your factory NPI intake already had the aluminum crossover, you can take the NPI aluminum crossovers and bolt it up to the new intake.
