pi or aftermarket
if you have the money to buy aftermarket cams I would just do a pi headswap.
posibly upgrade the springs wile you have them off so you can swap in cams later if you want more power. much easier to change springs with the head off.
then again if you want lope you will need something more agressive like an aftermarket setup.
Ummm, the Comp PI cams will work in NPI heads. You will need the Crower Offset retainers and upgraded springs to run some higher lift cams in the NPI heads. You will need these for the higher lift PI Comps. I would say the ideal cam for a mild modded car would be the Comp 262AH( PI ) Cam.
